Hi there;
I recently moved some very basic automations from HA to 2 Shelly2PM’s for redundancy and reliability reasons.
The new setup is as follows;
-2x Shelly 2PM’s - both with AddOns and 4x temperature Sensors.
-The Temperature sensors monitor two locations redundantly (2 x 2), and depending on the temperature, turn the fan motor on Low Speed or High Speed. There is also a safety Vent - which one Shelly can control, which vents the heat during low temperatures when you are no longer using the Wood Heater - or more likely, during long nights when the wood burns out (and I would like to use the electric heater).
However when I had it with HA, I had a Derivative sensor based on rate of temperature change. High values of rate-of-change over 3 cycles, followed by a long slow rate of change, indicated the Wood was burnt out and the unit was cooling down. I used this data-set to declare the Wood Heater burnt out in HA, then turn on my Daikin Electric Heater. The issue is, the Daikin, and Flu Fan, use the same ducting. I can’t run both together, hence I must interlock them.
Because everything is on the Shelly, and very basic, I have no real way to enable/disable it’s automations (actions). Previously I had a master input_boolean that dictated if the Flu Fan automation could run or not.
I need something similar within the Shelly 2PM’s. Does anyone know how to enable or disable the Shelly automations, or set - unset the equivalent of an input boolean within the Shelly Devices?
