SHelly plus + BLE no devices added in homeassistant
Hi, the Bermuda BLE Trilateration project could be better solution to use Shelly Plus devices as BT proxy. (GitHub - agittins/bermuda: Bermuda Bluetooth/BLE Triangulation / Trilateration for HomeAssistant) In this case, you don not need to setup any custom Shelly script because the built in HA script enough. Moreover, you do not need to use it via MQTT because the Bermuda project is an integration into HA and communicate with the Shelly devices via the native Shelly integration (which is not MQTT). I only use ESPresence project to get the IRK for Apple devices and I also use the HA’s builtin “Private BLE Device” integration to handle Apple BLE privacy… All solution is very simple. I hope it helps.
