mmz
(Matej)
November 8, 2021, 4:34pm
1
I’m trying to use RGBW2 as a 4xwhite output. I wan’t to expose all 4 lights as a single light in home assistant.
I was thinking I should do 4 PWM outputs, 4 monocromatic light entities and then some sort of switch to turn on all those lights and set brightness. Does anyone has this scenario working?
I would also like to have a few different multi-press switch configs:
single press: turn on/off
press-and-hold: dimming
double press: max power
triple press: 50% brightness
Anyone has anything like this working?
maxym
November 8, 2021, 4:49pm
2
What is the motivation behind this approach?
Shelly RGBW2 allows to set required values anytime (even when light is turned off). Then you can turn it on when needed. Saying that, additional switch on the output is not needed. The only “problem” is, that HA doesn’t support this feature. You have to set RGBW2 using mqtt or http API. Then on/off via HA light entity.
multi-press, if using native firmware of RGBW2 is kind of limited. It can max out on double-press for RGB mode. But not sure about 4ch mode.
One of your options is to set input as detached, then intercept input presses by some automation.
Don’t know what can Tasmota do.
mmz
(Matej)
November 9, 2021, 7:27am
3
What I want to have is a single light entity in Home Assistant controlling 2 or 4 light strips from the same RGBW2 conroller. I have multiple light strips in my room and they act as a single light, but I can’t drive all of them via a single output on RGBW2 as they are too powerful.
I could mix something up with MQTT and templated switches I guess in HA, but if there is a support for that in ESPHome, I would go that way.
Multi-press is something I really want to have and I don’t want to detach the switch as I want to have my buttons operational even when HA is down.
I guess my solution would be something in the line of:
binary_sensor:
- platform: gpio
on_press:
then:
- light.toggle: light1
- light.toggle: light2
- light.toggle: light3
But thinking about that, this will create a button entity in HA, but not a light entity, so I can’t configure brightness of a light.
maxym
November 9, 2021, 8:44am
4
you can also make 4 entities representing each channel, then group them into single light using light group.
mmz
(Matej)
November 10, 2021, 11:33am
5
So I found out, I can use light partition to group light together:
light:
- platform: partition
name: "Lobby livingroom light"
segments:
- single_light_id: output_component_left
- single_light_id: output_component_right
effects:
- random:
- pulse:
- strobe:
- flicker:
- platform: monochromatic
name: "Livingroom light left"
output: pwm_b
internal: true
name: "Livingroom light right"
output: pwm_w
internal: true
The problem is that I get a simple on/off light in HA now instead of dimmable LED light. Almost had it:)
maxym
November 12, 2021, 1:58pm
6
I’m not familiar to partition platform. I suggested light group
mmz
(Matej)
November 12, 2021, 2:23pm
7
Yes, partitions for monochromatic lights were released in the latest ESPHome version.
I now have a working example with button switch doing multiple thing:
single press: on/off
double press: full power
triple press: evening mode
long hold: slow dimming
substitutions:
devicename: lobby_livingroom_light
friendly_name: Lobby livingroom light
device_description: Shelly RGBW2 lobby livingroom light
esphome:
platform: ESP8266
# Set modwifi on shelly devices since they have 2MB of flash
board: modwifi
wifi:
ssid: !secret wifi_ssid
# Should make wifi signal better (https://www.die-welt.net/2020/04/controlling-roller-shutters-using-a-shelly-25-esphome-and-home-assistant/)
power_save_mode: none
fast_connect: true
manual_ip:
static_ip: 192.168.50.73
gateway: !secret ip_gateway
subnet: !secret ip_subnet
dns1: !secret ip_dns1
ap:
ssid: ${friendly_name}
password: !secret ap_password
captive_portal:
# Enable logging
logger:
# Enable Home Assistant API
api:
ota:
time:
# Sync RTC time with HA
- platform: homeassistant
text_sensor:
# Sensor with esphome versiona and fw build time
- platform: version
# Extra wifi info from device
- platform: wifi_info
ip_address:
ssid:
bssid:
# Reports the WiFi signal strength
- platform: wifi_signal
update_interval: 60s
# Reports how long the device has been powered (in minutes) since last reboot
- platform: uptime
filters:
- lambda: return x / 3600;
unit_of_measurement: "h"
switch:
- platform: restart
# RGBW2 Pings
# Red 12
# Green 15
# Blue 14
# White 04
# AC switch: 5 (input)
# Push button: 13 (input)
# Status led: 2
# Power usage: A0 (analog input)
output:
- platform: esp8266_pwm
pin: GPIO12
frequency: 1000 Hz
pin: GPIO15
frequency: 1000 Hz
pin: GPIO14
frequency: 1000 Hz
pin: GPIO4
frequency: 1000 Hz
light:
default_transition_length: 0.3s
segments:
- single_light_id: light_ch1
- single_light_id: light_ch2
- single_light_id: light_ch3
- single_light_id: light_ch4
output: out_ch1
internal: true
output: out_ch2
internal: true
output: out_ch3
internal: true
output: out_ch4
internal: true
binary_sensor:
- platform: status
- platform: gpio
pin:
number: GPIO5
name: "Livingroom light switch"
# internal: true
on_multi_click:
# Dimming
- timing:
- ON for at least 1s
then:
- logger.log: "Start dimming"
- while:
condition:
binary_sensor.is_on: light_touch
then:
- light.dim_relative:
relative_brightness: -5%
transition_length: 0.2s
- delay: 0.1s
# Double click
- timing:
- ON for at most 1s
- OFF for at most 0.5s
- ON for at most 1s
- OFF for at least 0.2s
then:
- logger.log: "Double Clicked - Full power"
- light.turn_on:
brightness: 100%
# Triple click
- timing:
- ON for at most 1s
- ON for at most 1s
- ON for at most 1s
then:
- logger.log: "Triple Clicked - Evening mode"
- light.turn_on:
brightness: 60%
# Toggle light
- timing:
- ON for at most 1s
- OFF for at least 0.5s
then:
- if:
condition:
- light.is_off: light_group
then:
- logger.log: "Single Short Clicked - toggle on"
- light.turn_on:
brightness: 100%
else:
- logger.log: "Single Short Clicked - toggle off"
- light.turn_off: light_group
status_led:
pin:
number: GPIO2
inverted: yes
