Shelly Weather Station
I just installed the weather station from Shelly, which is an Ecowitt WS90. I have in set up in HA two different ways. It is set up as a BTHome Sensor and using Zigbee2MQTT. I’m not sure why this is happening but each integration is getting different values from the weather station. Temp is about 1-2° off, wind speed, direction, humidity, etc are all differ a little from each other. Precipitation is in mm on MQTT and inches in BTHome. BtHome shows precipitation as 0 in and BTHome has it as 4.4mm. (It has been raining this morning). I also noticed that hte BTHome integration shows wind speed in mph whereas, MQTT shows it in m/s. The two also have different names for measurements- Rain status= on vs. Moisture= Wet, Pressure in psi vs. Atmospheric Pressure inHg. Both have wind direction in degrees. I’m just confused as to how the same weather station can have different readings based on the integration used in HA. For example- right now both integrations have Illuminance in lx. One raeads 85,310 lx and the other 85,055 lx.
So my question is; Which integration should I use? Is one better or more accurate than the other? Does one respond quicker to changes than the other?
I haven’t used BTHome myself, but it’s probably picking up your local standard units of measurement (so I’m assuming US given the units you described). Z2MQTT is going to being getting the raw data itself, no conversions.
I am just using a mixture of both integrations to get the data I want. One thing I have noticed is the rain guage doesnt reset. It rained about three days ago and the station still displays 2in of rain. Anyone know when this will reset?
I also discovered that if you connect the station via Zigbee, those sensors get stuck or do not display the correct values. I’m going to delete the Zigbee connection and just use the BTHome integration. There are sensors that are only available through the zigbee connection for some reason. For the sensors that I want to see, I’m going to create sensor templates. I’ve already created templates for wind chill and wind direction to display as text instead of degrees.
I’m yet to set up mine, but what is the state class of that sensor? If it’s total or total increasing, then you might need to make a utility meter with a daily cycle.
Its total increasing I believe. And yes I created a utility meter template to reset the daily rainfall. I just need to figure out how to make the template display “0” if no rain has fallen. Currently it says “unknown”. I’m assuming that is because no rain has fallen since I created the sensor template. Maybe when it resets it will display 0.
I’m not sure what you mean by “utility meter template”, but if you’re using this, then look at this:
always_available boolean (Optional, default: false)
If activated, the sensor will always be available with the last totalized value, even if the source entity is unavailable or unknown.
Otherwise, call the calibration function on the utility meter.
