Hi there
I’m relativly new to HA and just wired up my wall light buttons with a few Shelly Plus 1s.
I also have a few Philips Hue lights which I added to HA.
I want to be able to do the following:
- Turn the Light on and off over the light switch.
- Turn the Light on and off over the HA-App.
- Turn the Light on with the light switch and off with the HA-App (also other way around)
To achive this, I set the following Input/Output Settings in my Shelly:
Input Mode: Button
Set output type: Detached
Now when I press the button, HA gets an event from my button called “event.livingroom_button”.
Then I added the following automation:
alias: New Automation
description: ""
- platform: state
entity_id:
- event.livingroom_button
id: PRESS - livingroom_button
condition: []
- choose:
- conditions:
- condition: trigger
id:
- PRESS - Wohnzimmer_button
- condition: device
type: is_off
device_id: 8c13327f941706167104814a871fe0ca
entity_id: 2e909ee319873e94e5d76fbe60a655b3
domain: light
sequence:
- service: light.turn_on
metadata: {}
transition: 2
brightness_pct: 100
entity_id: light.philipps_enrave_licht
- conditions:
id:
- condition: device
type: is_on
domain: light
sequence:
- service: light.turn_off
entity_id:
- light.philipps_enrave_licht
transition: 2
mode: single
Now I can turn on the Philips Hue via the light switch and turn it off via the app, also the other way around. But I can’t figure out the following behaviour:
- Button Press → Light turns on
- Button Press → Light starts to turn off, but turns back on again
- Button Press → Light turns off
- Button Press → Light starts to turn on, but turns back off again
and so on…
Does anyone have an idea, why my Philips Hue behaves like that?
