Shelly4Hass - Change RBGW2 from RGW to 4-channel white
I run shelly4hass on Home Assistant. I included a Shelly RGBW2 set to “RGBW” into my network. Device was discovered. Then I set the RGBW2 in the web interface to “4-channel white”. But the device in Home Assistant is still representing the RGBW. How can I set the device to be a 4-channel white device?
I couldn’t find out how to delete the device or related entities. Web interface does not work, as integration is still controlled by config.yaml, Shelly1 is configured as light there.
Any other ideas?
Cheers Sven
