Then your title does not match what you write here… you want a shorter cycle … not realtime.
This dashboard is not meant for real time (and I would not want it to be), for RT you can use regular graphs.
However, not shure how the chances are to reduce to 30m cycles as the data comes from the statistics table and this stores it hourly so the whole statistics setup requires to be reviewed and it also creates more data, etc.
