Show highest value all-time
I’m looking for a way to show the maximum reached value of an entity. I already looked at the Min/Max value helper but that is only giving the me max value of today not all-time.
Is there a way to accomplish this?
Thanks!
I do this with an input_number and an automation:
- alias: Energy - max power recorder
  description: Updates the maximum power recorder whenever prior maximum is exceeded
    - platform: numeric_state
      entity_id: sensor.power_meter_house
      above: input_number.max_power
    - service: input_number.set_value
        entity_id: input_number.max_power
        value: "{{ states('sensor.power_meter_house')|float(0.0) }}"
If statistics are created then you could write q query on it with SQL, it will only kick back one value though
How do you get the value using SQL? And put it in a template.
SQL integration allows you to execute a SQL query (dûh :slight_smile: ) against a database. Yoiu just need to know how to write it which is (interesting) not for all.
I can try to provide an example
  • what is you database (mariadb / sqlite)?
  • what is the timespan from which you want the highest value, e.g. (today - 12mths) to > today or just without timespan?
  • are you 100% sure that the data is in statistics? Else the only option is ‘history’ but this is only 1-20-ish days old
EDIT: you can also try to get this ‘once’ by a manual query on the db, then put it in the input_number along what @Troon suggested and it will be updated as of then
You can use a Trigger-based Template Sensor.
template:
  - trigger:
      - platform: state
        entity_id: sensor.your_sensor
      - name: Your Sensor Maximum
        state: >
          {{ [trigger.to_state.state, this.state] | map('float', -99) | max }}
This is still based on ‘now’, the OP asked for all-time…
You suggestion seems to be similar as what @troon wrote, if would work as of sensor creation, correct?
On the side, so your suggestion would compare what value is stored ‘now’ and only update is it is higher?
I would like to add that both other (non-query) methods also work without the need to having statistics… so this may be the way forward
You’re absolutely right, it depends on what homest means by “all time”.
  • If it means including the entity’s values from the past then they’ll have to use SQL to query the database.
  • If it mean the entity’s values starting from now and into the future then they can use a Trigger-based Template Sensor.
