🌡️ Show Temperature Trend with Icon, Color and Text in Home Assistant (with button-card)
Want to see whether the temperature is rising or falling – with a matching icon, color, and text? Here’s a simple yet powerful solution using a combination of derivative, template, and button-card.
:white_check_mark: Features:
  • :arrow_up_small::arrow_down_small: Icon changes depending on the trend
  • :art: Icon and text color reflect whether temperature is rising, falling, or stable
  • :receipt: Text shows “rising”, “falling” or “stable”
  • :thermometer: Temperature display
  • :iphone: Tap opens more info
:package: Prerequisites
  1. Install button-card via HACS
  2. Your outdoor temperature sensor (e.g. sensor.indoor_outdoor_temperatur) should be available and updating regularly
:abacus: 1. Create a Derivative Sensor
Add this to your configuration.yaml to calculate the temperature trend:
  - platform: derivative
    source: sensor.indoor_outdoor_temperatur
    unit_time: h
    time_window: "00:30:00"
This compares the temperature over the last 30 minutes.
:receipt: 2. (Optional) Create a Textual Trend Sensor
Add this to your templates.yaml (or use template: directly):
template:
  - sensor:
      - name: Temperature Trend Text
        state: >
          {% set trend = states('sensor.temperature_trend') | float %}
          {% if trend > 0.1 %}
            rising
          {% elif trend < -0.1 %}
            falling
          {% else %}
            stable
          {% endif %}
:brick: 3. Create the Button Card in Lovelace
Paste the following into your dashboard (YAML view or raw config editor):
type: custom:button-card
entity: sensor.indoor_outdoor_temperatur
name: Outdoor Temperature
show_state: true
show_icon: true
show_name: true
tap_action:
  action: more-info
icon: >
    const trend = states['sensor.temperature_trend'].state;
    if (parseFloat(trend) > 0.1) return 'mdi:thermometer-chevron-up';
    if (parseFloat(trend) < -0.1) return 'mdi:thermometer-chevron-down';
    return 'mdi:thermometer';
state_display: >
    return entity.state + " °C";
custom_fields:
  trend: >
      const trend = parseFloat(states['sensor.temperature_trend'].state);
      if (trend > 0.1) return "rising";
      if (trend < -0.1) return "falling";
      return "stable";
styles:
  card:
    - padding: 16px
    - border-radius: 12px
    - box-shadow: 2px 2px 6px rgba(0,0,0,0.1)
    - background-color: '#ffffff20'
  icon:
    - color: >
          if (trend > 0.1) return 'red';
          if (trend < -0.1) return 'blue';
          return 'gray';
    - width: 40px
    - height: 40px
  name:
    - font-weight: bold
    - font-size: 18px
  state:
    - font-size: 22px
    - font-weight: 600
  custom_fields:
    trend:
      - font-size: 14px
      - color: >
            return 'gray';
      - margin-top: 4px
Thanks for sharing.
Just tried this. Rebooted in between.
When I create the button card and copy your code in I get
ButtonCardJSTemplateError: TypeError: can’t access property “state”, entity is undefined in ‘return entity.state + " °C";’
