Show used ports
Can home assistant show me a list of ports currently used by the add-ons? This is prompted by the 8555 already in use when trying to install Frigate.
In the Advanced SSH & Web Terminal community add-on with protection mode disabled:
sudo netstat -tulpn | grep LISTEN
For the records, -l already gives you the listening tcp ports only, so the grep is superfluous.
OTOH, there is a conflict between asking for udp ports (-u) and grepping for “LISTEN”
What I meant is that netstat -tlnp gives you the same output as netstat -tulpn | grep LISTEN
