Showing another Hassio Instance as a view tabs
Hello guys!
Since I am now using two different instances of Home Assistant on my network, I wonder if it is possible to add the other HA instance on each other GUI as a view tab.
For example:
This is Hassio number 1:
This is Hassio number 2:
Has anyone done that? I’ve tried creating a new view tab, set as a panel and ad the iframe card using the direct IP address to the other instance. That did not worked since I can see the section tab on the left and all view tabs inside this single view tab.
I also would not like to use the panel iframe on the left since the mobile view hides it to better show the main dashboard.
Not sure if was able to express myself correctly. I just need to be able to access both instances on the same dashboard.
Thanks!
