Showing two Units of Measurement on one line
I am using a LPG Tank % Level Gauge with Hall Effect device to report % left in tank using the following config:
# LPG 1410L Tank Level Monitor
  - platform: adc
    pin: GPIO36
    # raw: true
    name: "LPG Tank Level"
    update_interval: 10s
# Additional LPG Tank Variables
    unit_of_measurement: "%"
    accuracy_decimals: 1
    filters:
    - multiply: 100
Resulting in this Lovelace card:
Ha! It’s just coincidence that the Tank Level % & Outside Temp are the same numbers - I also have a Dallas DS18B20 sensor on this ESP32 node.
I would like the card to show as follows:
‘LPG Tank Volume / Level 319 L / 22.6 %’
Is it possible to achieve this in the .yaml code?
I look forward to reading your suggestions.
Thanks,
Steve
That’s possible with a custom frontend row: https://github.com/thomasloven/lovelace-template-entity-row
Once installed (preferably using HACS), you can add some custom yaml in the card:
- type: custom:template-entity-row
    entity: sensor.one_sensor
    state: LPG Tank Volume / {{ states('sensor.foo') }} L / {{ states('sensor.bar') }} %
I hope that gets you a start :slight_smile:.
Edit: I see this is in the ESPHome topic, yet I’d still suggest to have your ESPHome device send the individual unprocessed sensors over to HA, and have the custom view there.
You can also calculate the litres from the % sensor via a template
If you create a text sensor in esphome and by using lambda the features .state
id(my_sensor).state
@stevenma Yep simple it is all in your pin
  - platform: adc
    pin: GPIO36 #check your pin is correct
    # raw: true
If you are unsure just post your full code and I will have a look.
you have 2 sensors yea one for LPG and one for Temp. Temp will be on pin 36 what is your LPG sensor on?
OK, firstly many thanks to each of you for coming back to me so promptly with your suggested solutions - but - I’m still struggling after a couple of hours! Please assume novice level knowledge / expertise!
I have searched in HACS but can’t see ‘lovelace-template-entity-row’ (or thomasloven) or how to achieve the install / integration from there.
I have also tried downloading from the Github Raw button to a file in Windows File Manager. Would I need to install Samba to transfer the file to my Raspberry Pi HA installation?
I’m now trying to install the custom frontend row from here:
Following the instructions here: Lovelace Plugins · thomasloven/hass-config Wiki · GitHub
it seems that:
git clone https://github.com/thomasloven/template-entity-row
is the best way but I cannot see where to run the git command from. There is a git button with options: git init, git commit, git push & git stash. Should I be using one of those?
I have file editor and have created a folder called www.
Any further assistance you can offer will be helpful please.
Many thanks,
Steve
Thanks Blacky,
Here is my code less the WiFi particulars:
esphome:
  platform: ESP32
  board: esp32doit-devkit-v1
dallas:
  - pin: GPIO22
# Enable logging
logger:
# Enable Home Assistant API
api:
ota:
  password: "xxxx"
wifi:
  ssid: "BTHomeHub2-4R2S"
  password: "xxxx"
  manual_ip:
    static_ip: 192.168.1.70
    gateway: 192.168.1.254
    subnet: 255.255.255.0
    dns1: 8.8.8.8
    dns2: 8.8.4.4
  ap:
    ssid: "Esp-Test Fallback Hotspot"
    password: "xxxx"
# WiFi Signal Level
  - platform: wifi_signal
    name: "WiFi Signal Sensor"
    update_interval: 60s
  - platform: adc
    pin: GPIO36
    # raw: true
    filters:
    - multiply: 100
# Outside Temperature
  - platform: dallas
    address: 0xcf0000047c79a128
    name: "Outside Temperature"
captive_portal:
Wrt HACS, make sure you’re searching for frontend, not integrations. It’s called “template-entity-card”.
con I see your logs… only need to see data
really need to see your logs though to set calibration and check things. What sensor are you using for LPG
esphome:
  platform: ESP32
dallas:
  - pin: GPIO22
# Enable logging
logger:
api:
ota:
  password: "xxxx"
wifi:
  password: "xxxx"
  manual_ip:
    dns1: 8.8.8.8
    dns2: 8.8.4.4
  ap:
    password: "xxxx"
# WiFi Signal Level
  - platform: adc
    pin: GPIO36
    icon: "mdi:gas-cylinder"
    accuracy_decimals: 0
    attenuation: 11db
    filters:
###    - multiply: 0.00095238 # 3.9/4095, for attenuation 11db
    - median:
        window_size: 60
        send_every: 60
        send_first_at: 6
    - calibrate_linear:
          - 0.56 -> 0.0
          - 2.89 -> 100.0
    - lambda: |
        if (x < 0.0) return 0.0;
        else if (x > 100.0) return (x);
        else return (x);
  - platform: dallas
captive_portal:
OK, I think I’ve cracked it:
I used this approach:
@Blacky
I am using a Rochester 5v Hall Effect gauge which responds to the magnet on a float inside the tank. The gauge replaces the existing one and is non-invasive otherwise it wouldn’t be possible to replace a faulty gauge without emptying the tank. I use a level shifter resistor network to drop the voltage to 3.3v Of course it won’t be super accurate but it doesn’t need to be - I just need to know when we’re getting very low and plan, in due course, to try to better calibrate then measure daily / weekly etc. usage.
Thank you for the responses, in particular use of the attenuation factor - I need to better understand that and will research further when I get in to the calibration phase.
Thanks again for your responses, it’s much appreciated as I wouldn’t have got here without your help.
Regards,
Steve
No problem.
Thanks for the update
