I have a strange issue with my SHT31XD sensor. I’m constantly has a “trying to reconnect” error. or sometimes depending on the frequency of “communication error”. other times it is just working fine ( it looks independent from the config). I have another BH1750 sensor wired to the same pins which are working fine all the time.
I tried:
- standalone ( everything else disconnected)
- different pins
- different configs
- different frequencies
- Set the sensor type to SHT4X I am getting data although not correct ( which is expected)
My config is:
i2c:
- id: bus_a
sda: D2
scl: D1
scan: true
- platform: sht3xd
i2c_id: bus_a
temperature:
humidity:
name: "Relative Humidity LR"
#address: 0x44
update_interval: 60s
- platform: bh1750
i2c_id: bus_a
name: "BH1750 Illuminance"
#address: 0x23
measurement_duration: 69
I have the following line in the log:
[11:08:34][C][i2c.arduino:037]: I2C Bus:
[11:08:34][C][i2c.arduino:038]: SDA Pin: GPIO4
[11:08:34][C][i2c.arduino:039]: SCL Pin: GPIO5
[11:08:34][C][i2c.arduino:040]: Frequency: 50000 Hz
[11:08:34][C][i2c.arduino:043]: Recovery: bus successfully recovered
[11:08:34][I][i2c.arduino:053]: Results from i2c bus scan:
[11:08:34][I][i2c.arduino:059]: Found i2c device at address 0x23
[11:08:34][I][i2c.arduino:059]: Found i2c device at address 0x44
[11:08:34][C][sht3xd:034]: SHT3xD:
[11:08:34][C][sht3xd:035]: Address: 0x44
[11:08:34][C][sht3xd:039]: Update Interval: 60.0s
[11:08:34][C][sht3xd:041]: Temperature 'Temperature LR'
[11:08:34][C][sht3xd:041]: Device Class: 'temperature'
[11:08:34][C][sht3xd:041]: State Class: 'measurement'
[11:08:34][C][sht3xd:041]: Unit of Measurement: '°C'
[11:08:34][C][sht3xd:041]: Accuracy Decimals: 1
[11:08:34][C][sht3xd:042]: Humidity 'Relative Humidity LR'
[11:08:34][C][sht3xd:042]: Device Class: 'humidity'
[11:08:34][C][sht3xd:042]: State Class: 'measurement'
[11:08:34][C][sht3xd:042]: Unit of Measurement: '%'
[11:08:34][C][sht3xd:042]: Accuracy Decimals: 1
[11:08:34][C][bh1750.sensor:027]: BH1750 'BH1750 Illuminance'
[11:08:34][C][bh1750.sensor:027]: Device Class: 'illuminance'
[11:08:34][C][bh1750.sensor:027]: State Class: 'measurement'
[11:08:34][C][bh1750.sensor:027]: Unit of Measurement: 'lx'
[11:08:34][C][bh1750.sensor:027]: Accuracy Decimals: 1
[11:08:34][C][bh1750.sensor:028]: Address: 0x23
[11:08:34][C][bh1750.sensor:048]: Resolution: 0.5
[11:08:34][C][bh1750.sensor:049]: Update Interval: 60.0s
[11:08:51][D][bh1750.sensor:085]: 'BH1750 Illuminance': Got illuminance=321.2lx
[11:08:51][D][sensor:125]: 'BH1750 Illuminance': Sending state 321.25000 lx with 1 decimals of accuracy
[11:09:04][D][sht3xd:047]: Retrying to reconnect the sensor.
