Shutter control for knx switches
Hi, I’ve recently switched from comfort click to HA. Everything in my house is knx based, but I don’t have the ETS file and I won’t have it. I started manually finding all the addresses for the lights and it works great. The shutters are a problem. I can only get them to work as light, not switches. When I define them as light, using the “brightness” works to make them close to a spesific position, But that way there is no “stop” action. I couldn’t for the life of me understand how to use covers, even after reading here for weeks.
Is there a simple way to configure the shutters? I don’t need sun or weather automation, just the basic open, close, stop and position. Thanx!
Hi :wave:!
You shouldn’t use the switch nor light platform, but cover for that.
https://www.home-assistant.io/integrations/knx/#cover
