Shutters with Tasmota
Hello everybody. I have a sonoff touch 2 channel wall switch to control a shutter. I’ve flashed tasmota and want to control it with home assistant. It does work standalone. Tasmota plugin in home assistant did find the switch, but i only get a bunch of sensors, e.g. shutter direction, current position and target (plus a couple of deactivated). It should have added a cover, but did not.
Ok… nut sure why, but after some server restarts (and update to newest 2021 ha version) the cover is discovered correct.
