SigEnergy Integration Can't Control Battery
Hi All - Following the excellent posts in this community, I managed to connect to our SigEnergy Inverter & Battery to gather data and control the battery mode via RMS. It was working really well - no issues at all really. However, our inverter was subject to a recall and replaced with a new one (just as well as the original one melted down a few days after the recall notice was issued).
I set the IP address of the new inverter in the plant integration and accepted the port and slave_ID defaults (ID 247??), but … Although the sensors of the inverter are available (and most of the original battery sensors) the command to take control of the battery now fails to work. I’ve tried reloading it a few times and the person that installed the plant has spoken with the SigEnergy support team - but no luck yet.
Any ideas?
It turns out that there is some weirdness in the IP address routing - tha inverter claims it is connected to .201 whilst the router says .217
Anyway, setting the HA integration to 201 solves the issue.
