Hi, i have a slow_pwm speed controller and can perfectly set the speed by a lambda call: as mentioned in the esp-documentation under output.set_level
Action: like: id(slow_pwm_thsol).set_level(pwr);
script:
- id: thsol_power_set
parameters:
pwr: float
then:
- lambda: |-
if (pwr < 0.4) {
id(slow_pwm_thsol).turn_off() ;
} else {
id(slow_pwm_thsol).turn_on() ;
Now changing the speed controller to “sigma_delta_output” i can no more set the speed by the set_level command.
Setting manually as a number like 0.8 works fine…
Where is the bug `?
output:
#- platform: sigma_delta_output
- platform: slow_pwm
pin: GPIO13
period: 1000ms
# update_interval: 200ms
inverted: false
min_power: 0.40
max_power: 1.00
# Sets the output to use actual 0 instead of min_power
zero_means_zero: true
turn_on_action:
- switch.turn_on: pwm_check
turn_off_action:
- switch.turn_off: pwm_check
zoogara
(Daryl)
April 16, 2025, 1:16am
2
Post your sigma_delta_output:
yaml, if that’s the one not working. Also post logs showing the attempted level change.
friendly_name: PWM2
esp32:
board: az-delivery-devkit-v4 #esp32dev
framework:
type: arduino
# Enable logging
logger:
level: VERY_VERBOSE # Like debug, but a few more messages that are usually deemed to be
# # spam are also included. Color: grey
# Enable Home Assistant API
api:
encryption:
key: "3z0XylrZItTyLhny9qq6J9xGMHvftIItFn6BlIl+CfE="
# Over the air Zugriff
ota:
- platform: esphome
password: "aee3c10b647e6c19de676e66175e7ed5"
# wifi
wifi:
ssid: !secret wifi_ssid
on_disconnect:
- wifi.disable:
- delay: 15s
- wifi.enable:
ap:
ssid: "Esp32-041 Fallback Hotspot"
password: "30073007"
captive_portal:
# power ex HA an ESP übergeben
- platform: homeassistant
entity_id: input_number.pumpenpower_thsol
accuracy_decimals: 2
accuracy_decimals: 0
update_interval: 10s
lambda: |-
id(thsol_power_set).execute(id(power).state) ;
return {1} ;
script:
parameters:
pwr: float
then:
- lambda: |-
if (pwr < 0.4) {
} else {
output:
pin: GPIO13
update_interval: 1000ms
inverted: false
min_power: 0.40
max_power: 1.00
turn_on_action:
turn_off_action:
switch:
optimistic: True
Pls dont be confused, i just replaced the sigma_delta_output versus the slow_pwm names…
Here is the relevant LOG:
INFO ESPHome 2025.3.3
INFO Reading configuration /config/esphome/pwm2.yaml…
INFO Starting log output from 192.168.2.129 using esphome API
INFO Successfully connected to pwm2 @ 192.168.2.129 in 0.088s
INFO Successful handshake with pwm2 @ 192.168.2.129 in 0.152s
[19:14:18][I][app:100]: ESPHome version 2025.3.3 compiled on Apr 16 2025, 18:55:33
[19:14:18][C][wifi:600]: WiFi:
[19:14:18][C][wifi:428]: Local MAC: A0:B7:65:2C:5A:88
[19:14:18][C][wifi:433]: SSID: ‘GUANOLISK’[redacted]
[19:14:18][C][wifi:436]: IP Address: 192.168.2.129
[19:14:18][C][wifi:440]: BSSID: 7C:FF:4D:AF:DA:1E[redacted]
[19:14:18][C][wifi:441]: Hostname: ‘pwm2’
[19:14:18][C][wifi:443]: Signal strength: -46 dB ▂▄▆█
[19:14:18][V][wifi:445]: Priority: 0.0
[19:14:19][C][wifi:447]: Channel: 6
[19:14:19][C][wifi:448]: Subnet: 255.255.255.0
[19:14:19][C][wifi:449]: Gateway: 192.168.2.1
[19:14:19][C][wifi:450]: DNS1: 192.168.2.1
[19:14:19][C][wifi:451]: DNS2: 0.0.0.0
[19:14:19][VV][scheduler:226]: Running interval ‘update’ with interval=1000 last_execution=9050 (now=10105)
[19:14:19][C][logger:177]: Logger:
[19:14:19][C][logger:178]: Max Level: VERY_VERBOSE
[19:14:19][C][logger:179]: Initial Level: VERY_VERBOSE
[19:14:19][C][logger:181]: Log Baud Rate: 115200
[19:14:19][C][logger:182]: Hardware UART: UART0
[19:14:19][C][template.sensor:022]: Template Sensor ‘pumpencheck’
[19:14:19][C][template.sensor:022]: State Class: ‘’
[19:14:19][C][template.sensor:022]: Unit of Measurement: ‘’
[19:14:19][C][template.sensor:022]: Accuracy Decimals: 0
[19:14:19][C][output.sigma_delta:024]: Turn off automation configured
[19:14:19][C][output.sigma_delta:026]: Update Interval: 1.0s
and
after changing the input number from HA
19:14:52][VV][scheduler:226]: Running interval ‘update’ with interval=1000 last_execution=43050 (now=44056)
[19:14:52][VV][api.service:831]: on_home_assistant_state_response: HomeAssistantStateResponse {
entity_id: ‘input_number.pumpenpower_thsol’
state: ‘0.86’
attribute: ‘’
[19:14:52][D][homeassistant.sensor:024]: ‘input_number.pumpenpower_thsol’: Got state 0.86
[19:14:52][V][sensor:043]: ‘power’: Received new state 0.860000
[19:14:52][D][sensor:094]: ‘power’: Sending state 0.86000 with 2 decimals of accuracy
[19:14:53][VV][scheduler:226]: Running interval ‘update’ with interval=1000 last_execution=44050 (now=45053)
[19:14:53][VV][scheduler:226]: Running interval ‘update’ with interval=60000 last_execution=4294952411 (now=45115)
meaning that value was taken over as power…
But sigma_delta_output does not respond…
Do you need any more LOGs ??
some more information:
if i set a fix outputpower like
id(slow_pwm_thsol).set_level(0.8);
and leave all the rest, the log ouput changes like that:
[19:43:26][C][template.switch:057]: Optimistic: YES
[19:43:26][C][output.sigma_delta:015]: Sigma Delta Output:
[19:43:26][C][output.sigma_delta:016]: Pin: GPIO13
[19:43:26][C][output.sigma_delta:021]: Turn on automation configured
[19:43:26][C][output.sigma_delta:024]: Turn off automation configured
[19:43:26][C][output.sigma_delta:026]: Update Interval: 1.0s
[19:43:26][C][output.sigma_delta:027]: Min Power: 40.0%
[19:43:26][C][captive_portal:089]: Captive Portal:
with the former variable power like:
id(slow_pwm_thsol).set_level(id(power).state);
the logoutput was like:
[19:14:20][VV][scheduler:226]: Running in
so it seems, not to fully get the sigma_delta_output definitions…
So far …
BR
Norbert
So my conclusio is, that sigma_delta_output can NOT work with set_output funktion…
Karosm
(Karosm)
April 16, 2025, 8:36pm
6
There’s not function like that on your code.
The differences between your two setups are very difficult to follow.
HI, sorry. Confused ".set_level " with “.set_output ”…
So it should read as:
“So my conclusio is, that sigma_delta_output does NOT work with set_level funktion…”
neither directly in ESPHOME nor as a LAMBDA function.
