Hi guys,
I´m new to HassIo but was rather please about the easy setup on my Raspi4 with the current SD image. My hue bridge and all devices were discovered, are accessible, so far, so good.
Then I got myself the above USB device to connect Zwave devices (devolo thermostats for that matter). I installed DeConz, configured the Serial port and the logs tell me that the stick is at least recognized. But that´s about it. It is not possible to add any devices, the WebUI doesnt recognize the firmware…
I googled the error messages but nothing that I found could help. Am I missing something ?
Raspi4 2GB
HassOS 3.5
Hardware list :
serial:
/dev/serial/by-id/usb-0658_0200_E3040B02-4A02-010C-320B-041600CC95C0-if00
/dev/ttyACM0
/dev/ttyAMA0
/dev/ttyS0
input:
deconz firmware: 2.5.69
starting version 232
[21:11:09] INFO: Starting VNC server...
[21:11:13] INFO: Starting the deCONZ gateway...
[21:11:13] INFO: Running the deCONZ OTA updater...
[21:11:13] INFO: Running the IKEA OTA updater...
[21:11:13] INFO: Running Hass.io discovery task...
libEGL warning: DRI2: failed to open swrast (search paths /usr/lib/arm-linux-gnueabihf/dri:${ORIGIN}/dri:/usr/lib/dri)
{"uuid":"589d7e31ceee4a83a96efaaf3a18fb25"}
[21:11:13] INFO: Success send discovery information to Home Assistant
[21:11:13] INFO: deCONZ is set up and running!
libpng warning: iCCP: known incorrect sRGB profile
21:11:13:763 HTTP Server listen on address 0.0.0.0, port: 40850, root: /usr/share/deCONZ/webapp/
21:11:13:786 CTRL. 3.16.221:11:13:872 dev /dev/ttyAMA0
21:11:13:872 COM: /dev/ttyACM0 / serialno: E3040B02-4A02-010C-320B-041600CC95C0
21:11:13:872 COM: --dev: /dev/ttyACM0 (ConBee II)
21:11:13:872 ZCLDB init file /data/.local/share/dresden-elektronik/deCONZ/zcldb.txt
21:11:13:980 parent process bash
21:11:13:980 gw run mode: docker/hassio
21:11:13:980 GW sd-card image version file does not exist: /data/.local/share/dresden-elektronik/deCONZ/gw-version
21:11:13:980 sd-card cid: 9c534f555344303002ffffffff013200
21:11:13:982 DB sqlite version 3.16.2
21:11:13:983 DB PRAGMA page_count: 30
21:11:13:983 DB PRAGMA page_size: 4096
21:11:13:983 DB PRAGMA freelist_count: 0
21:11:13:983 DB file size 122880 bytes, free pages 0
21:11:13:983 DB PRAGMA user_version: 6
21:11:13:983 DB cleanup
21:11:13:984 DB create temporary views
21:11:13:989 don't close database yet, keep open for 900 seconds
21:11:13:989 started websocket server at port 40860
21:11:13:994 found node plugin: libde_rest_plugin.so - REST API Plugin
21:11:13:997 found node plugin: libde_signal_plugin.so - Signal Monitor Plugin
21:11:15:212 found node plugin: libstd_otau_plugin.so - STD OTAU Plugin
21:11:15:239 dev /dev/ttyAMA0
21:11:15:239 COM: /dev/ttyACM0 / serialno: E3040B02-4A02-010C-320B-041600CC95C0
21:11:15:239 COM: --dev: /dev/ttyACM0 (ConBee II)
21:11:15:829 device state timeout ignored in state 2
21:11:16:829 device state timeout ignored in state 2
21:11:17:830 device state timeout ignored in state 2
21:11:18:224 New websocket 192.168.178.38:46858 (state: 3)
21:11:18:830 device state timeout ignored in state 2
21:11:18:871 dev /dev/ttyAMA0
21:11:19:651 Announced to internet
21:11:19:652 discovery server date: Tue, 05 Nov 2019 20:11:19 GMT
21:11:19:652 local time seems to be ok
21:11:19:652 discovery found version 2.04.35 for update channel stable
21:11:19:830 device state timeout ignored in state 2
21:11:20:830 device state timeout (handled)
21:11:21:329 void zmMaster::handleStateIdle(zmMaster::MasterEvent) not connected goto OFF state
21:11:21:329 device state timeout ignored in state 1
21:11:21:829 wait reconnect 15 seconds
21:11:22:829 wait reconnect 14 seconds
21:11:23:833 wait reconnect 13 seconds
21:11:24:830 wait reconnect 12 seconds
21:11:25:829 wait reconnect 11 seconds
21:11:26:829 wait reconnect 10 seconds
21:11:27:830 wait reconnect 9 seconds
21:11:28:830 wait reconnect 8 seconds
21:11:28:867 dev /dev/ttyAMA0
21:11:28:867 GW update firmware found: /usr/share/deCONZ/firmware/deCONZ_ConBeeII_0x26490700.bin.GCF
21:11:29:830 wait reconnect 7 seconds
21:11:30:830 wait reconnect 6 seconds
21:11:31:830 wait reconnect 5 seconds
21:11:32:829 wait reconnect 4 seconds
21:11:33:829 wait reconnect 3 seconds
21:11:34:829 wait reconnect 2 seconds
21:11:35:830 wait reconnect 1 seconds
21:11:35:874 dev /dev/ttyAMA0
21:11:35:874 COM: /dev/ttyACM0 / serialno: E3040B02-4A02-010C-320B-041600CC95C0
21:11:35:874 COM: --dev: /dev/ttyACM0 (ConBee II)
21:11:36:373 device state timeout ignored in state 2
21:11:37:330 device state timeout ignored in state 2
21:11:38:329 device state timeout ignored in state 2
21:11:39:329 device state timeout ignored in state 2
21:11:40:330 device state timeout ignored in state 2
21:11:41:330 device state timeout (handled)
21:11:41:829 wait reconnect 15 seconds
21:11:41:830 void zmMaster::handleStateIdle(zmMaster::MasterEvent) not connected goto OFF state
21:11:41:830 device state timeout ignored in state 1
21:11:42:247 scan skip host .38
21:11:42:830 wait reconnect 14 seconds
21:11:43:830 wait reconnect 13 seconds
21:11:44:830 wait reconnect 12 seconds
21:11:45:829 wait reconnect 11 seconds
21:11:46:830 wait reconnect 10 seconds
21:11:47:830 wait reconnect 9 seconds
21:11:48:830 wait reconnect 8 seconds
21:11:49:830 wait reconnect 7 seconds
21:11:50:830 wait reconnect 6 seconds
21:11:51:829 wait reconnect 5 seconds
21:11:52:830 wait reconnect 4 seconds
21:11:53:033 scan finished
21:11:53:830 wait reconnect 3 seconds
