When following your recipe, I get the following errors in HA:
Logger: homeassistant.setup
Source: setup.py:278
First occurred: 10:17:43 (1 occurrence)
Last logged: 10:17:43
Setup failed for custom integration 'gree_silent': No setup or config entry setup function defined.
and
Source: setup.py:372
The 'gree_silent' integration does not support YAML setup, please remove it from your configuration
Any idea maybe?
EDIT: If others make the same mistake: the file name shouldn’t be init.py but __init__ .py (with double underscores before and under the init).
You’re right, the file must be named __init__.py
I’ll correct the info in the Gist. Thanks for reporting it.
By the way, since today, I received a firmware update (1.44) which is no more working with this kind of hack and the bip are get back… I din’t found any workaround now with the latest firmware, so if you want to supress the bip, please do not upgrade to the latest firmware!
@sonic1200
Just wanted to say thank you so much for this ! I've been struggling with the beeping sounds for the past 5 years and 2 out of my 4 units are now silent
I'll try updating the firmware on the others to see if that's the issue.
