Hi, thanks for replying just saw this but it still won’t send me an SMS…
Code:
esphome:
platform: ESP32
board: esp32dev
# Enable logging
logger:
baud_rate: 0
level: VERBOSE
# Enable Home Assistant API
api:
password: ""
ota:
password: ""
wifi:
ssid: "XXX"
password: "XXX"
ap:
ssid: "Hot-Water-Lake-Esp32"
password: "iAZP1T0BOxke"
captive_portal:
# defining sensors:
# relay:
switch:
- platform: gpio
pin: GPIO26
# sim:
uart:
baud_rate: 9600
tx_pin: GPIO1
rx_pin: GPIO3
sim800l:
# dallas temperature sensor:
dallas:
- pin: GPIO32
# conditions:
- platform: dallas
address: 0x2e0319a27968ac28
name: "Water Temperature ESP32"
on_value_range:
- below: 24.0
then:
- sim800l.send_sms:
recipient: 'XXX'
message: Cold
- above: 32.0
then:
- sim800l.send_sms:
recipient: 'XXX'
message: Hot
binary_sensor:
- platform: sim800l
name: "Sim800L Registered"
- platform: gpio
pin: GPIO25
on_press:
then:
- sim800l.send_sms:
recipient: 'XXX'
message: Hot
# deep_sleep:
# run_duration: 2min
# sleep_duration: 58min
I tried to isolate the SMS problem so I made a trigger that suppose to send me an SMS whenever I press the button but it still ain’t working.
this is the logs:
PS C:\Coding\Home Assistant\Water Temp\Test> esphome logs test.yml
INFO Reading configuration test.yml...
INFO Starting log output from hot-lake.local using esphome API
INFO Successfully connected to hot-lake.local
[17:53:47][I][app:102]: ESPHome version 2022.10.2 compiled on Dec 3 2022, 23:33:05
[17:53:47][C][wifi:502]: WiFi:
[17:53:47][C][wifi:360]: Local MAC: 4C:11:AE:F9:7A:94
[17:53:47][C][wifi:361]: SSID: 'vadai'
[17:53:47][C][wifi:362]: IP Address: 192.168.1.5
[17:53:47][C][wifi:364]: BSSID: AC:84:C6:46:38:DA
[17:53:47][C][wifi:365]: Hostname: 'hot-lake'
[17:53:47][C][wifi:367]: Signal strength: -57 dB ▂▄▆█
[17:53:47][V][wifi:369]: Priority: 0.0
[17:53:47][C][logger:276]: Level: VERBOSE
[17:53:47][C][logger:277]: Log Baud Rate: 0
[17:53:47][C][logger:278]: Hardware UART: UART0
[17:53:47][C][uart.arduino_esp32:107]: UART Bus:
[17:53:47][C][uart.arduino_esp32:108]: TX Pin: GPIO1
[17:53:47][C][uart.arduino_esp32:109]: RX Pin: GPIO3
[17:53:47][C][uart.arduino_esp32:111]: RX Buffer Size: 256
[17:53:47][C][uart.arduino_esp32:113]: Baud Rate: 9600 baud
[17:53:47][C][uart.arduino_esp32:114]: Data Bits: 8
[17:53:47][C][uart.arduino_esp32:115]: Parity: NONE
[17:53:47][C][uart.arduino_esp32:116]: Stop bits: 1
[17:53:47][C][switch.gpio:050]: GPIO Switch 'Relay'
[17:53:48][C][gpio.binary_sensor:015]: GPIO Binary Sensor 'Button'
[17:53:48][C][gpio.binary_sensor:016]: Pin: GPIO25
[17:53:48][C][sim800l:463]: SIM800L:
[17:53:48][C][sim800l:465]: Registered 'Sim800L Registered'
[17:53:48][C][sim800l:465]: Device Class: 'connectivity'
[17:53:48][C][dallas.sensor:075]: DallasComponent:
[17:53:48][C][dallas.sensor:076]: Pin: GPIO32
[17:53:48][C][dallas.sensor:077]: Update Interval: 60.0s
[17:53:48][D][dallas.sensor:082]: Found sensors:
[17:53:48][D][dallas.sensor:084]: 0x2e0319a27968ac28
[17:53:48][C][dallas.sensor:089]: Device 'Water Temperature ESP32'
[17:53:48][C][dallas.sensor:089]: Device Class: 'temperature'
[17:53:48][C][dallas.sensor:089]: State Class: 'measurement'
[17:53:48][C][dallas.sensor:089]: Unit of Measurement: '°C'
[17:53:48][C][captive_portal:088]: Captive Portal:
[17:53:48][C][mdns:100]: mDNS:
[17:53:48][C][mdns:101]: Hostname: hot-lake
[17:53:48][V][mdns:102]: Services:
[17:53:48][V][mdns:104]: - _esphomelib, _tcp, 6053
[17:53:48][V][mdns:106]: TXT: version = 2022.10.2
[17:53:48][V][mdns:106]: TXT: mac = 4c11aef97a94
[17:53:48][V][mdns:106]: TXT: platform = ESP32
[17:53:48][V][mdns:106]: TXT: board = esp32dev
[17:53:48][V][mdns:106]: TXT: network = wifi
[17:53:48][C][ota:089]: Over-The-Air Updates:
[17:53:48][C][ota:090]: Address: hot-lake.local:3232
[17:53:48][C][api:138]: API Server:
[17:53:48][C][api:139]: Address: hot-lake.local:6053
[17:53:48][C][api:143]: Using noise encryption: NO
[17:53:55][D][esp32.preferences:113]: Saving 1 preferences to flash...
[17:53:55][V][esp32.preferences:136]: NVS data not changed skipping 1938662975 len=1
[17:53:55][D][esp32.preferences:142]: Saving 1 preferences to flash: 1 cached, 0 written, 0 failed
[17:54:10][D][api:102]: Accepted ::FFFF:C0A8:10C
[17:54:10][V][api.connection:899]: Hello from client: 'Home Assistant 2022.11.4 (::FFFF:C0A8:10C)' | API Version 1.7
[17:54:10][W][api.connection:083]: Home Assistant 2022.11.4 (::FFFF:C0A8:10C): Connection closed
[17:54:10][V][api:114]: Removing connection to Home Assistant 2022.11.4 (::FFFF:C0A8:10C)
[17:54:20][D][binary_sensor:036]: 'Button': Sending state OFF
[17:54:20][D][binary_sensor:036]: 'Button': Sending state ON
[17:54:45][D][dallas.sensor:143]: 'Water Temperature ESP32': Got Temperature=20.6°C
[17:54:45][V][sensor:076]: 'Water Temperature ESP32': Received new state 20.625000
[17:54:45][D][sensor:127]: 'Water Temperature ESP32': Sending state 20.62500 °C with 1 decimals of accuracy
[17:54:55][D][esp32.preferences:113]: Saving 1 preferences to flash...
[17:54:55][V][esp32.preferences:136]: NVS data not changed skipping 1938662975 len=1
[17:54:55][D][esp32.preferences:142]: Saving 1 preferences to flash: 1 cached, 0 written, 0 failed
If you would be able to look over it and help me that would be awesome
thanks anyway
