Simple Adjusted Value Sensor
This blueprint will help you create sensors that take the numeric state of an entity and then offset that value by a fixed value, the value of another entity’s numeric state, or both.
blueprint:
  author: Didgeridrew
  homeassistant:
    min_version: 2025.1.0
  name: Simple Adjusted Value
  description: |
    Creates a sensor which holds the adjusted value of a reference entity's state.
    Offsetting by static value, another entity's state, or both are allowed.
  domain: template
  input:
    reference_entity:
      description: The entity that needs to have its value adjusted.
      selector:
          entity:
            multiple: false
            filter:
              - domain:
                  - sensor
                  - number
                  - input_number
                  - counter
    fixed_offset:
      name: Fixed Offset Value
      description: |
        Numeric offset added to the sensors value.
        Please use negative values to subtract.
      default: 0
      selector:
        number:
          mode: box
          min: -5000
          max: 5000
    my_section:
      icon: mdi:cog
      description: "These options allow you to use an entity's state as your offset."
      input:
        offset_entity:
          description: |
            The entity whose state value should be used as an offset.
            By default this value will be **added** to the source
            Please check the box below if this value should be subtracted.
          default: "sensor.example_offset"
          selector:
              entity:
                multiple: false
                filter:
                  - domain:
                      - sensor
                      - number
                      - input_number
                      - counter
        subtract:
          name: Subtract offset entity value
          default: false
          selector:
            constant:
              value: true
              label: Offset Entity Value will be subtracted.
variables:
  reference_entity: !input reference_entity
  fixed_offset: !input fixed_offset
  offset_entity: !input offset_entity
  subtract: !input subtract
  state: |
    {{ (states(reference_entity) | float(0) + fixed_offset | float(0) + this.attributes.entity_offset) | round(1) }}
  attributes:
    fixed_offset: "{{ fixed_offset }}"
    entity_offset: |
      {% set init = 0 if offset_entity is undefined or offset_entity in
      [none, "None", "sensor.example_offset"] else states(offset_entity) | float(0) %}
      {% set invert = -1 if subtract else 1 %}
      {{ invert * init }}
  state_class: measurement
  icon: |
    {{ state_attr(reference_entity, 'icon') | default('mdi:plus-minus-variant', 1) }}
  availability: "{{ has_value(reference_entity) }}"
Template Blueprints are currently (2025.05) only available through YAML configuration. You can find more details about how to use them at: HA Docs - Templates - Using Blueprints
Once you have installed the blueprint, you can use the following configurations as examples to create working sensors in your configuration.yaml file:
template:
  - name: Adjusted Living Room Humidity
    use_blueprint:
      path: Didgeridrew/simple-adjusted-value-sensor.yaml
      input:
        reference_entity: sensor.living_room_humidity
        fixed_offset: -5.0
template:
  - name: In/Out Humidity Difference
    use_blueprint:
      input:
        reference_entity: sensor.indoor_humidity
        offset_entity: sensor.outdoor_humidity
        subtract: true
