sparkydave
(🇦🇺 Dave)
January 8, 2018, 12:40am
1
Hi All,
I am trying to write my first script but it fails the built-in config checker. Can someone please point out what I am doing wrong here? I have tried to use someones example on GitHub and it is so similar that I just dont see where the problem is.
bedtime.yaml
sequence:
- service: homeassistant.turn_off
entity_id: media_player.lounge_tv
- service: switch.turn_off
entity_id: switch.amp_power
- service: homeassistant.turn_on
entity_id: light.bedroom_lamp
brightness: 50
this is what i get in the log:
2018-01-08 08:32:38 ERROR (MainThread) [homeassistant.config] Invalid config for [script]: expected a dictionary for dictionary value @ data[‘script’]. Got [OrderedDict([(‘sequence’, [OrderedDict([(‘service’, ‘homeassistant.turn_off’), (‘data’, OrderedDict([(‘entity_id’, ‘media_player.lounge_tv’)]))]), OrderedDict([(‘service’, ‘switch.turn_off’), (‘data’, OrderedDict([(‘entity_id’, ‘switch.amp_power’)]))]), OrderedDict([(‘service’, ‘homeassistant.turn_on’), (‘data’, OrderedDict([(‘entity_id’, ‘light.bedroom_lamp’), (‘brightness’, 50)]))])])])]. (See ?, line ?). Please check the docs at Scripts - Home Assistant
2018-01-08 08:32:38 ERROR (MainThread) [homeassistant.setup] Setup failed for script: Invalid config.
keithh666
(Keith Hull)
January 8, 2018, 12:57am
2
I don’t think you need data: for the first two and the for last one try light.turn_on
sparkydave
(🇦🇺 Dave)
January 8, 2018, 1:10am
3
I just tried it and it still fails…
2018-01-08 09:01:20 ERROR (MainThread) [homeassistant.config] Invalid config for [script]: expected a dictionary for dictionary value @ data[‘script’]. Got [OrderedDict([(‘sequence’, [OrderedDict([(‘service’, ‘homeassistant.turn_off’), (‘entity_id’, ‘media_player.lounge_tv’)]), OrderedDict([(‘service’, ‘switch.turn_off’), (‘entity_id’, ‘switch.amp_power’)]), OrderedDict([(‘service’, ‘light.turn_on’), (‘data’, OrderedDict([(‘entity_id’, ‘light.bedroom_lamp’), (‘brightness’, 50)]))])])])]. (See ?, line ?). Please check the docs at Scripts - Home Assistant
2018-01-08 09:01:20 ERROR (MainThread) [homeassistant.setup] Setup failed for script: Invalid config.
sparkydave
(🇦🇺 Dave)
January 8, 2018, 1:16am
4
the reasoning behind having data:
in there was simply because its what I have seen in the GitHub example I was referring to:
sequence:
- service: input_boolean.turn_off
entity_id: input_boolean.movie_mode_light
- condition: state
entity_id: switch.living_room_ceiling_light
state: 'on'
entity_id: switch.switch.living_room_ceiling_light
- service: light.turn_on
entity_id: light.couch_lights
but also in the docs:
service: switch.turn_on
entity_id: switch.skylight_close
keithh666
(Keith Hull)
January 8, 2018, 1:19am
5
I think it’s because you haven’t given it a name…
as it’s complaining about sequnce by the looks of it…
example_script: <----------------------try naming it
sequence:
# This is written using the Script Syntax
entity_id: light.ceiling
- service: notify.notify
message: 'Turned on the ceiling light!'
sparkydave
(🇦🇺 Dave)
January 8, 2018, 1:30am
6
Nope. That didn’t work either. I don’t believe it needs a name since it’s in it’s own yaml file.
From the ‘examples’ page on the HA website I worked from this:
Here there is no name and Teagan has used the data:
line which is why I did too…
keithh666
(Keith Hull)
January 8, 2018, 1:47am
7
Maybe it’s something to do with the way you are loading the file?
sparkydave
(🇦🇺 Dave)
January 8, 2018, 2:27am
8
I created it with the IDE addon in HassIO. The structure of the filing system is:
config folder> configuration.yaml
script: !include_dir_list scripts
config folder> scripts folder> bedtime.yaml
sequence:
brightness: 50
I haven’t tried to run the script reload function and test it out as it hasn’t passed the config validation
sparkydave
(🇦🇺 Dave)
January 8, 2018, 7:11am
9
So I tried something else via the IDE editor by creating a scripts.yaml with pretty much the same code but adding in the name and alias and that passes the config check… what is going on here?
scripts.yaml
bedtime:
alias: Turn TV and Amp off and turn on bedroom lamp
sequence:
rgb_color: [226, 147, 36]
brightness: 200
- delay: '00:05:00'
- service: light.turn_off
transition: 60
Why does the above pass but my previous code in it’s own yaml file fails?
Because you’re using merge_list when it should be merge_named
sparkydave
(🇦🇺 Dave)
January 8, 2018, 9:17pm
11
umm ok…? It’s the same way I have all my automations… I’ll give it a try. Thanks!
Automations are written in lists.
Scripts are written with names.
When you merge them with includes you must merge them in the correct format
sparkydave
(🇦🇺 Dave)
January 8, 2018, 9:55pm
13
ok, thanks for the clarification.
