Hello all,
I have managed to setup my climate integration to control the boiler in my house and it is working nicely. However I am having some weird problems with the simple thermostat card that I use. The best way to describe the problem is with a picture:
AS you can see, the card look ok for the most part except for the two arrows above and below the target temperature. I am using the dark theme for the interface and I assume that the arrows are also black. How can I change them to white for example? or any other color so I can see them.
Cheers
