Apologies if the answer is obvious, really noob to home assistant IO, literally just set it up a supervised homeassistant on my RPi 3 a week ago, although I have had quite a bit of experience dealing with RPi and Linux in general.
For the first warm up automation task I was planning to basically turn on a smart switch that connected to my bedroom heater at 10pm (if I am at home so that my home doesn’t burn into ashes if the heater catches fire!), and then as a second task turn it off after an hour later (i.e., at 11pm).
So for the turn on task, I set my trigger as the following:
platform: time
at: '22:00:00'
(I have also tried to set it to be after 22:00:00, also no luck.)
Trigger:
condition: state
entity_id: person.MY (and I have the Android app installed and I can see my status is Home in the Developer Tools -> Current Entities)
state: HOME
and finally actions:
type: turn_on
device_id: xxxxxxx
entity_id: switch.heater
domain: switch
My turn off automation is very similar except the Trigger is defined as following (and no conditions):
platform: device
type: turned_on
device_id: xxxxx
domain: switch
for:
hours: 1
minutes: 0
seconds: 0
But this Automation doesn’t seem to run at 10pm and if I turn it on manually, the turn off automation doesn’t execute either.
Here are a few things I have thought about to try to fix the issue.
When I press the execute button (i.e., manually execute it), both automation tasks correctly turns the device on/off (even before 10pm), I assume this is because when I execute the timed portion of the task is ignored? However this seems to suggest the integration between Google home and home assistant is configured properly in my case and the action is configured properly.
Checking using dpkg-reconfigure tzdata I can verify my timezone is set correctly to my home timezone. Also showing the correct timezone in my Configuration page
There is no log book entry at 10pm, as if the tasks were never executed automatically.
Just wondering if I am thinking about this correctly or there is some stupid noob mistake I am making here. Also is there a log file that I can check in the supervised HA to see if there is any thing preventing this to run?
Here is my configuration page for reference:
System Health
version | 2020.12.1 |
installation_type | Home Assistant Supervised |
dev | false |
hassio | true |
docker | true |
virtualenv | false |
python_version | 3.8.6 |
os_name | Linux |
os_version | 5.4.79-v7+ |
arch | armv7l |
timezone | xxxxxxxx |
Home Assistant Cloud
logged_in | false |
can_reach_cert_server | ok |
can_reach_cloud_auth | ok |
can_reach_cloud | ok |
Hass.io
host_os | Raspbian GNU/Linux 10 (buster) |
update_channel | stable |
supervisor_version | 2020.12.7 |
docker_version | 20.10.1 |
disk_total | 58.1 GB |
disk_used | 14.5 GB |
healthy | true |
supported | failed to load: Unsupported |
supervisor_api | ok |
version_api | ok |
installed_addons | Ring Devices (4.2.1) |
Lovelace
dashboards | 1 |
mode | auto-gen |
resources | 0 |
Thanks in advance for your help!
