Simplisafe -- Invalid credentials provided
Simplisafe used to work but no longer does; my password and pin are correct and I even updated the component to the latest from “master” and am still receiving this error. Are other folks seeing the same?
I’m seeing the same thing. It stopped working for me a couple of weeks ago.
The log shows: “Invalid credentials provided,” and it references components/simplisafe/__init__.py.
I see it on my main Home Assistant setup, which runs on a Raspberry Pi 2 Model B using Home Assistant Core with a virtual environment.
I also see it on the same Raspberry Pi using a different microSD card on which I am experimenting with Home Assistant (old Hass.io).
