Simplistic configuration UI
Time for another update: 0.2.8
What’s new?
  • Updated CDN libraries (Ace Editor, jQuery etc.)
  • Cosmetic improvements
  • Added event observer
A brief description of the event observer:
Inspired by this thread I implemented a simple WebSocket client that subscribes to the event-stream via the HASS API. If it connects successfully, all events that happen on HASS’ event-bus are printed in their raw format for you to analyze. If for example you have a new button-device and want to figure out what kind of event it emits, just follow the output of the event observer.
This is basically the same as running HASS in the debug log-level and following the log, minus everything that’s being logged that’s not event-related.
The configurator tries it’s best to guess how the API can be reached on its own (basically at the same location where it accesses the HASS API itself). This should work pretty well if you have the HASS_API option set to your external host (like when you expose to the internet). If it’s set to localhost because it’s running on the HASS host, then of course this can’t work because you usually don’t have HASS running the client-machine. In this case you have to manually enter the correct URI.
Hope this is useful for some of you. :slight_smile:
