Hello community,
I have an annoying problem.
I use automations to trigger e.g. adjusted brightness of the lighting in different time periods or conditions.
So it happens that some automations overlap in time, but not their conditions.
Example:
Automation “Corridor evening” with the time window 22:00-6:00 (10pm-6am) regulates the lighting in the corridor to 20%.
Automation “Corridor day” takes over from 6:00-18:00 (6am-6pm) and regulates to 60% etc.
However, if the “Bedtime” mode is active, the “Corridor Bedtime” automation takes over and sets the lighting to 5%, regardless of the time window.
Now it sometimes happens that you realise that the automation is actually triggered for a time window, but is immediately overwritten by “Bedtime”. The light flashes briefly (e.g. at 60%) and immediately jumps to 5%.
I don’t know why this is the case, because all automations query whether the “Sleep time” mode is active or not and should therefore prevent it from being executed.
Can anyone tell me what could be the reason for this? Do I have an error in the process?
Automation “Bedtime”:
alias: "Badezimmer: Licht ein bei Anwesenheit (Schlafenszeit)"
description: ""
triggers:
- type: occupied
device_id: 1c395c0021239e44ff706924d996e513
entity_id: 6a5ca052c2f14312f8e5c8ba2a6adc67
domain: binary_sensor
trigger: device
conditions:
- condition: numeric_state
entity_id: input_number.schlafenszeit
above: 0
actions:
- action: light.turn_on
metadata: {}
rgb_color:
- 255
- 180
- 107
brightness_pct: 1
entity_id:
- light.deckenleuchte_badezimmer_segment_001
- light.deckenleuchte_badezimmer_segment_005
- light.deckenleuchte_badezimmer_segment_009
mode: single
Automation Evening:
alias: "Badezimmer: Licht ein bei Anwesenheit (Abend)"
description: ""
triggers:
- type: occupied
trigger: device
conditions:
- condition: time
after: "18:00:00"
before: "22:00:00"
below: 1
actions:
metadata: {}
brightness_pct: 15
kelvin: 3700
entity_id:
mode: single
