I have 5 hikvision IPC-B220 cameras that have been working fine for two years with HA until recent upgrade to 2023.1
The log is below - It’s not credentials as they previously worked - any ideas here? Thanks
Logger: homeassistant.components.onvif
Source: components/onvif/device.py:137
Integration: ONVIF (documentation, issues)
First occurred: 07:43:03 (5 occurrences)
Last logged: 20:31:07
- Couldn’t connect to camera ‘HIKVISION IPC-B220’, please verify that the credentials are correct. Error: Invalid data
- Couldn’t connect to camera ‘one’, please verify that the credentials are correct. Error: Invalid data
- Couldn’t connect to camera ‘two’, please verify that the credentials are correct. Error: Invalid data
- Couldn’t connect to camera ‘three’, please verify that the credentials are correct. Error: Invalid data
- Couldn’t connect to camera ‘four’, please verify that the credentials are correct. Error: Invalid data
What version was working, it seem the ONVIF integration has that problem since version 2022.8.1, they might have fixed it , check out the github.
