Since a recent update my USB zwave hub no longer shows up in hardware. I just cant find a way to make it work so help is appreciated
HAOS or docker?
Don’t spare the details!
EDIT
Check cable
Can you access command line? Check /dev for device. If not there hardware issue.
Try another usb port as well.
Hi yes i can access command line I have no detection of the device, and I tried another port. There is power to the port. I bypased the cable and plugged direct. Just never sees the usbn. I tried a different hub and same problem
