Hi all
I am migrating from Openhab to Homeassistant and thought I am on a good way. Most of my devices are MQTT and I added a voice assistant (alexa) which works perfectly.
ISSUE I have now
Since I upgraded homeassistant to the latest version (I was like 2 versions behind) it started persistently to either turn off lights of rooms or turn on.
=> for example it turned on the lights of my office all 2 min on (between 1-2min)
=> or it turned off the lights in the cellar between 10sec and 30sec where my wife worked
=> or my son cam at 1am to me and said “please stop turning on the light”
I HAD TO TURN OFF NOW HOMEASSISTANT… I found it funny… my family somehow not…
What I tested
- First I thought is was the EMqx, so I turned it off… no change
- then I turned it on again and thought I need to disable retain… no change
- then I turned off homeassistant… THAT HELPED
- then I changed in office the mqtt cmnd string … no change
- then I thought it is Alexa, I disconnected it comepletely… no change
- then I deleted all devices from Alexa… no change
- then I disconnected HA from Internet… thought i got hacked… no change
=> I believe that homeassistant does over rpc contact my shelly and onoff and turn it to a state that homeassistant believes is the right one
You can imagine that I can do only limited tests while my family is here… what should I do?
- Downgrade?
- check logs?
- setup from 0?
How would you approach the error finding… I am sure it started since I upgraded to the latest version but if I do not want to get killed, I need to know what I test before I turn HA again haha
