šŸ’” Single button on/off/dim switch v2
If anyone wants to try a Shelly i4 blueprint used in button mode so you dont loose any features of the device, see here…
I must be a complete idiot, i cant get this to work with my lightbee switch that is set up as a PTM 215Z in Z2MQTT.
i get a ā€œpressedā€ command and a ā€œreleasedā€ command when i push a button.
i’ve found some different blueprints an one of them needs a binary sensor to work but my button cant do that.
i’m so damn confused about this.
this problem is the only reason i havent moved all my things from the HUE hub to HA yet, since this function already works in HUE i cant see why it is not standard feature in HA or at least an easy fix for HA.
It’s easier than you think:
