Single youtube api request with parsed results to rest json_attributes
I’ve been struggling with a problem for a while now.
I’m trying to run a single youtube api request and get the last five videoIDs from the request and then create an html-template-card from those five IDs.
I’ve had success create five separate request but would like to consolidate to one as each query -with a 100 “price”- means I can only do 100 queries a day.
My thought was to try and parse my request and extract the videoID and add them as sensor attributes.
I can parse the json request using this method: $.items[:0].id.videoId but I’m not sure how to translate this to Jinja2. The request results are nested.
A response result with only two items looks like this for the Dev Tools Template:
{% set value_json = {
   "kind":"youtube#searchListResponse",
   "etag":"ikzEL69Ko8m2pdzUzxAVQ82caKs",
   "nextPageToken":"CAUQAA",
   "regionCode":"CA",
   "pageInfo":{
      "totalResults":924,
      "resultsPerPage":5
   "items":[
         "kind":"youtube#searchResult",
         "etag":"9vPq06Fozbyt0GhnC05L-NYb0r8",
         "id":{
            "kind":"youtube#video",
            "videoId":"t1NUH8xDcAY"
         "snippet":{
            "publishedAt":"2022-05-27T08:11:46Z",
            "channelId":"UCagiBBx1prefrlsDzDxuA9A",
            "title":"Elon Musk & The Cold Hard TRUTH About Billionaires",
            "description":"Join Patreon: https://www.patreon.com/solvingthemoneyproblem BlockFi Bitcoin Rewards Card https://bit.ly/3wlnXFn ...",
            "thumbnails":{
               "default":{
                  "url":"https://i.ytimg.com/vi/t1NUH8xDcAY/default.jpg",
                  "width":120,
                  "height":90
               "medium":{
                  "url":"https://i.ytimg.com/vi/t1NUH8xDcAY/mqdefault.jpg",
                  "width":320,
                  "height":180
               "high":{
                  "url":"https://i.ytimg.com/vi/t1NUH8xDcAY/hqdefault.jpg",
                  "width":480,
                  "height":360
            "channelTitle":"Solving The Money Problem",
            "liveBroadcastContent":"none",
            "publishTime":"2022-05-27T08:11:46Z"
         "etag":"b9tJB_ZQCFZ0IVwEVqzzVPqtTf4",
         "id":{
            "videoId":"NbkBZolmksg"
         "snippet":{
            "publishedAt":"2022-05-27T03:58:28Z",
            "title":"Tesla Stock SOARS As Elon Squeeze's Twitter’s 🍒s",
            "thumbnails":{
               "default":{
                  "url":"https://i.ytimg.com/vi/NbkBZolmksg/default.jpg",
                  "width":120,
                  "height":90
               "medium":{
                  "url":"https://i.ytimg.com/vi/NbkBZolmksg/mqdefault.jpg",
                  "width":320,
                  "height":180
               "high":{
                  "url":"https://i.ytimg.com/vi/NbkBZolmksg/hqdefault.jpg",
                  "width":480,
                  "height":360
            "publishTime":"2022-05-27T03:58:28Z"
{{ value_json["items"][1].id.videoId}}
Maybe my approach is wrong. Any suggestions would be appreciated. Thank you.
You can just use the map filter to transform a list by pulling out one attribute from each item:
{{ value_json["items"][:5]
    | map(attribute="id.videoId") | list }}
Also that won’t throw an error even if there’s less then 5, jinja just takes the rest if you picked a number larger then the length.
This was what I was looking for and worked well thank you for the reply.
When I try to create my card it treat the list as a complete string. So for example, something like this which I though would get the second element, simply returns the the characters starting at the second index.
{{states.sensor.youtube_second_latest_video.state[2:]}}
Initially I thought something like this would be the quick solution for my first element.
{{states.sensor.youtube_second_latest_video.state[0]}}
But this fails.
Thanks for your help.
