@claudegel Thanks for the great work and support with the Sinopé products.
Do you think Sinopé’s will make the push notifications available in their API. As of now, waiting up to (5) minutes to have HA know that a water leak occurred can feel like a million year.
Hi @Michel17 I don’t think that Sinopé will open there API to give us access to data pushed by the devices. But you can connect different device directly to the valve, light, switch, power controler. I just add the support in neviweb130 for those device connected directly to the valve.
I think that if the valve detect a leak it could open the light or open or close de switch directly without even talking to Neviweb. This could be usefull if you have a pump connected to your water supply and you need to trun off the pump in case of water leak.
I’ll check if we can catch the data pushed by Neviweb. On thing you can try. If you redirect your email to your HA it is possible to read them automatically in HA and do automations with that. This is what I’m doing for hydro peak. When I get the email from hydro it is redirected to my HA and I set all automations to be ready for the peak period automatically.
