SkyConnect failing to be discovered upon boot
Hi All!,
The issue I am having is my recently purchased SkyConnect USB module is not being automatically recognised by Home Assistant OS 2023.11.2 on my Pi4 (in an Argon M.2 Case) upon boot.
I don’t see SkyConnect appearing on the ‘Hardware’ section like many of the guides show.
I can see it when I look into ‘‘All Hardware’’ under one of the USB sockets:
I also do not see any appearance of ‘SkyConnect’ appearing in the ‘Integrations’ section like many of the guides.
I can only see it being detected when I manually add the ZHA integration and have to ‘select a serial port’
I had previously used Conbee II but I since deleted all integrations and records to ensure there were no clashes. I’ve done a few hard reboots too with no real progress.
My long term objective is to get this working and then to enable thread support.
Any help would be appreciated! Thanks.
