SkyConnect Multi-PAN Error after Update
Yesterday i make the Update to Multi-PAN in Home Assistant GUI.
Before my SkyConnect Stick running perfectly, without any porblems.
The Update running without any error.
But now my SkyConnect Stick show me a error
Any solution?
Same here. Problems also with 2023.2.2
you have a idea, what we can do?
i think the stick is bricked.
I have exactly the same problem here!
Restarted my Home Assistant Server last night, after which it threw some errors about not recognizing my pi hardware. Had to restore from backup, still no Zigbee connectivity. Tried to reconfigure the radio, but that always ran into an unknown error, the logs said the following:
  File "/usr/src/homeassistant/homeassistant/config_entries.py", line 382, in async_setup
    result = await component.async_setup_entry(hass, self)
  File "/usr/src/homeassistant/homeassistant/components/zha/__init__.py", line 111, in async_setup_entry
    await zha_gateway.async_initialize()
  File "/usr/src/homeassistant/homeassistant/components/zha/core/gateway.py", line 189, in async_initialize
    raise exc
  File "/usr/src/homeassistant/homeassistant/components/zha/core/gateway.py", line 174, in async_initialize
    self.application_controller = await app_controller_cls.new(
  File "/usr/local/lib/python3.10/site-packages/zigpy/application.py", line 169, in new
    await app.startup(auto_form=auto_form)
  File "/usr/local/lib/python3.10/site-packages/zigpy/application.py", line 146, in startup
    await self.initialize(auto_form=auto_form)
  File "/usr/local/lib/python3.10/site-packages/zigpy/application.py", line 122, in initialize
    await self.start_network()
  File "/usr/local/lib/python3.10/site-packages/zigpy_deconz/zigbee/application.py", line 118, in start_network
    raise FormationFailure() from e
zigpy.exceptions.FormationFailure
2023-02-05 18:40:56.216 ERROR (MainThread) [aiohttp.server] Error handling request
2023-02-05 18:40:59.836 ERROR (MainThread) [homeassistant] Error doing job: Task exception was never retrieved
  File "/usr/src/homeassistant/homeassistant/config_entries.py", line 1161, in async_setup
    raise OperationNotAllowed(
homeassistant.config_entries.OperationNotAllowed: The config entry SkyConnect Multi-PAN (zha) with entry_id d58aae25fc2ba6316495479f0d93fb36 cannot be setup because is already loaded in the ConfigEntryState.SETUP_ERROR state
Had to reflash firmware with the method described here.
I deleted the ZHA integration completely and build a new network with the SkyConnect stick and did a restore of my Zigbee Network, followed by another full restore of Home Assistant to a time where everything was still running.
2023-02-05 20:00:47.301 WARNING (MainThread) [homeassistant.components.zha.core.gateway] Couldn't start EZSP = Silicon Labs EmberZNet protocol: Elelabs, HUSBZB-1, Telegesis coordinator (attempt 1 of 3)
2023-02-05 20:00:51.398 WARNING (MainThread) [homeassistant.components.zha.core.gateway] Couldn't start EZSP = Silicon Labs EmberZNet protocol: Elelabs, HUSBZB-1, Telegesis coordinator (attempt 2 of 3)
2023-02-05 20:00:55.464 WARNING (MainThread) [homeassistant.components.zha.core.gateway] Couldn't start EZSP = Silicon Labs EmberZNet protocol: Elelabs, HUSBZB-1, Telegesis coordinator (attempt 3 of 3)
2023-02-05 20:00:55.470 ERROR (MainThread) [homeassistant.config_entries] Error setting up entry SkyConnect Multi-PAN for zha
I then tried migrating back to my old Sonoff Zigbee stick, which also was a hassle.
Now I have all my Zigbee entities back, but I can’t really control them reliably. Sometimes they accept the command, sometimes they don’t. When I now try to download my current ZHA config, an errors gets thrown.
2023-02-05 20:24:50.284 WARNING (MainThread) [homeassistant.components.zha.core.channels.base] [0xFAA5:11:0x0006]: async_initialize: all attempts have failed: [TimeoutError(), TimeoutError(), TimeoutError(), TimeoutError()]
2023-02-05 20:24:50.814 WARNING (MainThread) [homeassistant.components.zha.core.channels.base] [0xFAA5:11:0x0008]: async_initialize: all attempts have failed: [TimeoutError(), TimeoutError(), TimeoutError(), TimeoutError()]
2023-02-05 20:24:50.834 WARNING (MainThread) [homeassistant.components.zha.core.channels.base] [0x7D6F:11:0x0008]: async_initialize: all attempts have failed: [TimeoutError(), TimeoutError(), TimeoutError(), TimeoutError()]
2023-02-05 20:24:51.021 WARNING (MainThread) [homeassistant.components.zha.core.channels.base] [0x78B0:11:0x0006]: async_initialize: all attempts have failed: [TimeoutError(), TimeoutError(), TimeoutError(), TimeoutError()]
2023-02-05 20:24:51.150 WARNING (MainThread) [homeassistant.components.zha.core.channels.base] [0x78B0:11:0x0008]: async_initialize: all attempts have failed: [TimeoutError(), TimeoutError(), TimeoutError(), TimeoutError()]
2023-02-05 20:24:51.172 WARNING (MainThread) [homeassistant.components.zha.core.channels.base] [0x6C2E:11:0x0008]: async_initialize: all attempts have failed: [TimeoutError(), TimeoutError(), TimeoutError(), TimeoutError()]
2023-02-05 20:24:51.344 WARNING (MainThread) [homeassistant.components.zha.core.channels.base] [0x6C2E:11:0x0006]: async_initialize: all attempts have failed: [TimeoutError(), TimeoutError(), TimeoutError(), TimeoutError()]
2023-02-05 20:24:51.352 WARNING (MainThread) [homeassistant.components.zha.core.channels.base] [0x7D6F:11:0x0006]: async_initialize: all attempts have failed: [TimeoutError(), TimeoutError(), TimeoutError(), TimeoutError()]
2023-02-05 20:24:51.727 WARNING (MainThread) [homeassistant.components.zha.core.channels.base] [0xA1DB:1:0x0008]: async_initialize: all attempts have failed: [TimeoutError(), TimeoutError(), TimeoutError(), TimeoutError()]
2023-02-05 20:24:53.007 WARNING (MainThread) [homeassistant.components.zha.core.channels.base] [0xA1DB:1:0x0300]: async_initialize: all attempts have failed: [TimeoutError(), TimeoutError(), TimeoutError(), TimeoutError()]
2023-02-05 20:24:53.828 WARNING (MainThread) [homeassistant.components.zha.core.channels.base] [0x0F54:11:0x0008]: async_initialize: all attempts have failed: [DeliveryError('Request failed after 5 attempts: <Status.NWK_INVALID_REQUEST: 194>'), DeliveryError('Request failed after 5 attempts: <Status.NWK_INVALID_REQUEST: 194>'), DeliveryError('Request failed after 5 attempts: <Status.NWK_INVALID_REQUEST: 194>'), DeliveryError('Request failed after 5 attempts: <Status.NWK_INVALID_REQUEST: 194>')]
2023-02-05 20:24:53.884 WARNING (MainThread) [homeassistant.components.zha.core.channels.base] [0x0F54:11:0x0006]: async_initialize: all attempts have failed: [DeliveryError('Request failed after 5 attempts: <Status.NWK_INVALID_REQUEST: 194>'), DeliveryError('Request failed after 5 attempts: <Status.NWK_INVALID_REQUEST: 194>'), DeliveryError('Request failed after 5 attempts: <Status.NWK_INVALID_REQUEST: 194>'), DeliveryError('Request failed after 5 attempts: <Status.NWK_INVALID_REQUEST: 194>')]
2023-02-05 20:24:56.872 WARNING (MainThread) [homeassistant.components.zha.core.channels.base] [0xFC97:11:0x0008]: async_initialize: all attempts have failed: [TimeoutError(), TimeoutError(), TimeoutError(), TimeoutError()]
2023-02-05 20:24:57.077 WARNING (MainThread) [homeassistant.components.zha.core.channels.base] [0xD84B:11:0x0006]: async_initialize: all attempts have failed: [TimeoutError(), TimeoutError(), TimeoutError(), TimeoutError()]
2023-02-05 20:24:57.274 WARNING (MainThread) [homeassistant.components.zha.core.channels.base] [0x27A7:1:0x0b04]: async_initialize: all attempts have failed: [TimeoutError(), TimeoutError(), TimeoutError(), TimeoutError()]
2023-02-05 20:24:57.512 WARNING (MainThread) [homeassistant.components.zha.core.channels.base] [0x27A7:1:0x0702]: async_initialize: all attempts have failed: [TimeoutError(), TimeoutError(), TimeoutError(), TimeoutError()]
2023-02-05 20:24:57.576 WARNING (MainThread) [homeassistant.components.zha.core.channels.base] [0xFC97:11:0x0006]: async_initialize: all attempts have failed: [TimeoutError(), TimeoutError(), TimeoutError(), TimeoutError()]
2023-02-05 20:24:57.835 WARNING (MainThread) [homeassistant.components.zha.core.channels.base] [0x4960:1:0x0006]: async_initialize: all attempts have failed: [TimeoutError(), TimeoutError(), TimeoutError(), TimeoutError()]
2023-02-05 20:24:57.842 WARNING (MainThread) [homeassistant.components.zha.core.channels.base] [0x27A7:1:0x0006]: async_initialize: all attempts have failed: [TimeoutError(), TimeoutError(), TimeoutError(), TimeoutError()]
2023-02-05 20:24:57.878 WARNING (MainThread) [homeassistant.components.zha.core.channels.base] [0x4960:1:0x0002]: async_initialize: all attempts have failed: [TimeoutError(), TimeoutError(), TimeoutError(), TimeoutError()]
2023-02-05 20:24:57.890 WARNING (MainThread) [homeassistant.components.zha.core.channels.base] [0xD84B:11:0x0008]: async_initialize: all attempts have failed: [TimeoutError(), TimeoutError(), TimeoutError(), TimeoutError()]
2023-02-05 20:24:57.931 WARNING (MainThread) [homeassistant.components.zha.core.channels.base] [0x44CC:1:0x0b04]: async_initialize: all attempts have failed: [TimeoutError(), TimeoutError(), TimeoutError(), TimeoutError()]
2023-02-05 20:24:57.958 WARNING (MainThread) [homeassistant.components.zha.core.channels.base] [0xEEC5:1:0x0006]: async_initialize: all attempts have failed: [TimeoutError(), TimeoutError(), TimeoutError(), TimeoutError()]
2023-02-05 20:24:57.963 WARNING (MainThread) [homeassistant.components.zha.core.channels.base] [0x5768:11:0x0006]: async_initialize: all attempts have failed: [TimeoutError(), TimeoutError(), TimeoutError(), TimeoutError()]
2023-02-05 20:24:57.978 WARNING (MainThread) [homeassistant.components.zha.core.channels.base] [0x5D07:11:0x0006]: async_initialize: all attempts have failed: [TimeoutError(), TimeoutError(), TimeoutError(), TimeoutError()]
2023-02-05 20:24:58.000 WARNING (MainThread) [homeassistant.components.zha.core.channels.base] [0x4960:21:0x000c]: async_initialize: all attempts have failed: [TimeoutError(), TimeoutError(), TimeoutError(), TimeoutError()]
2023-02-05 20:24:58.022 WARNING (MainThread) [homeassistant.components.zha.core.channels.base] [0xEEC5:1:0x0702]: async_initialize: all attempts have failed: [TimeoutError(), TimeoutError(), TimeoutError(), TimeoutError()]
2023-02-05 20:24:58.068 WARNING (MainThread) [homeassistant.components.zha.core.channels.base] [0x5D07:11:0x0008]: async_initialize: all attempts have failed: [TimeoutError(), TimeoutError(), TimeoutError(), TimeoutError()]
2023-02-05 20:24:58.103 WARNING (MainThread) [homeassistant.components.zha.core.channels.base] [0x5768:11:0x0008]: async_initialize: all attempts have failed: [TimeoutError(), TimeoutError(), TimeoutError(), TimeoutError()]
2023-02-05 20:24:58.206 WARNING (MainThread) [homeassistant.components.zha.core.channels.base] [0xA41B:1:0x0002]: async_initialize: all attempts have failed: [TimeoutError(), TimeoutError(), TimeoutError(), TimeoutError()]
2023-02-05 20:24:58.209 WARNING (MainThread) [homeassistant.components.zha.core.channels.base] [0x44CC:1:0x0702]: async_initialize: all attempts have failed: [TimeoutError(), TimeoutError(), TimeoutError(), TimeoutError()]
2023-02-05 20:24:58.233 WARNING (MainThread) [homeassistant.components.zha.core.channels.base] [0xA41B:1:0x0006]: async_initialize: all attempts have failed: [TimeoutError(), TimeoutError(), TimeoutError(), TimeoutError()]
2023-02-05 20:24:58.278 WARNING (MainThread) [homeassistant.components.zha.core.channels.base] [0xC08D:1:0x0008]: async_initialize: all attempts have failed: [DeliveryError('Request failed after 5 attempts: <Status.NWK_INVALID_REQUEST: 194>'), DeliveryError('Request failed after 5 attempts: <Status.NWK_INVALID_REQUEST: 194>'), DeliveryError('Request failed after 5 attempts: <Status.NWK_INVALID_REQUEST: 194>'), DeliveryError('Request failed after 5 attempts: <Status.NWK_INVALID_REQUEST: 194>')]
2023-02-05 20:24:58.297 WARNING (MainThread) [homeassistant.components.zha.core.channels.base] [0xA41B:21:0x000c]: async_initialize: all attempts have failed: [TimeoutError(), TimeoutError(), TimeoutError(), TimeoutError()]
2023-02-05 20:24:58.563 WARNING (MainThread) [homeassistant.components.zha.core.channels.base] [0x44CC:1:0x0006]: async_initialize: all attempts have failed: [TimeoutError(), TimeoutError(), TimeoutError(), TimeoutError()]
2023-02-05 20:24:58.623 WARNING (MainThread) [homeassistant.components.zha.core.channels.base] [0x18CE:1:0x0006]: async_initialize: all attempts have failed: [DeliveryError('Request failed after 5 attempts: <Status.NWK_INVALID_REQUEST: 194>'), DeliveryError('Request failed after 5 attempts: <Status.NWK_INVALID_REQUEST: 194>'), DeliveryError('Request failed after 5 attempts: <Status.NWK_INVALID_REQUEST: 194>'), DeliveryError('Request failed after 5 attempts: <Status.NWK_INVALID_REQUEST: 194>')]
2023-02-05 20:24:58.657 WARNING (MainThread) [homeassistant.components.zha.core.channels.base] [0x18CE:1:0x0b04]: async_initialize: all attempts have failed: [DeliveryError('Request failed after 5 attempts: <Status.NWK_INVALID_REQUEST: 194>'), DeliveryError('Request failed after 5 attempts: <Status.NWK_INVALID_REQUEST: 194>'), DeliveryError('Request failed after 5 attempts: <Status.NWK_INVALID_REQUEST: 194>'), DeliveryError('Request failed after 5 attempts: <Status.NWK_INVALID_REQUEST: 194>')]
2023-02-05 20:24:58.663 WARNING (MainThread) [homeassistant.components.zha.core.channels.base] [0xEEC5:1:0x0b04]: async_initialize: all attempts have failed: [TimeoutError(), TimeoutError(), TimeoutError(), TimeoutError()]
2023-02-05 20:24:59.827 WARNING (MainThread) [homeassistant.components.zha.core.channels.base] [0xC08D:1:0x0006]: async_initialize: all attempts have failed: [DeliveryError('Request failed after 5 attempts: <Status.NWK_INVALID_REQUEST: 194>'), DeliveryError('Request failed after 5 attempts: <Status.NWK_INVALID_REQUEST: 194>'), DeliveryError('Request failed after 5 attempts: <Status.NWK_INVALID_REQUEST: 194>'), DeliveryError('Request failed after 5 attempts: <Status.NWK_INVALID_REQUEST: 194>')]
2023-02-05 20:24:59.882 WARNING (MainThread) [homeassistant.components.zha.core.channels.base] [0xC08D:1:0x0300]: async_initialize: all attempts have failed: [DeliveryError('Request failed after 5 attempts: <Status.NWK_INVALID_REQUEST: 194>'), DeliveryError('Request failed after 5 attempts: <Status.NWK_INVALID_REQUEST: 194>'), DeliveryError('Request failed after 5 attempts: <Status.NWK_INVALID_REQUEST: 194>'), DeliveryError('Request failed after 5 attempts: <Status.NWK_INVALID_REQUEST: 194>')]
2023-02-05 20:25:00.396 WARNING (MainThread) [homeassistant.components.zha.core.channels.base] [0x18CE:1:0x0702]: async_initialize: all attempts have failed: [DeliveryError('Request failed after 5 attempts: <Status.NWK_INVALID_REQUEST: 194>'), DeliveryError('Request failed after 5 attempts: <Status.NWK_INVALID_REQUEST: 194>'), DeliveryError('Request failed after 5 attempts: <Status.NWK_INVALID_REQUEST: 194>'), DeliveryError('Request failed after 5 attempts: <Status.NWK_INVALID_REQUEST: 194>')]
2023-02-05 20:25:06.050 WARNING (MainThread) [homeassistant.components.zha.core.channels.base] [0xA1DB:1:0x0006]: async_initialize: all attempts have failed: [TimeoutError(), TimeoutError(), TimeoutError(), TimeoutError()]
2023-02-05 20:25:06.482 WARNING (MainThread) [homeassistant.components.zha.core.channels.base] [0xA1DB:1:0x0300]: async_initialize: all attempts have failed: [TimeoutError(), TimeoutError(), TimeoutError(), TimeoutError()]
2023-02-05 20:25:26.472 WARNING (MainThread) [homeassistant.components.zha.core.channels.base] [0xEE50:2:0x0400]: async_initialize: all attempts have failed: [DeliveryError('Request failed after 5 attempts: <Status.NWK_INVALID_REQUEST: 194>'), DeliveryError('Request failed after 5 attempts: <Status.NWK_INVALID_REQUEST: 194>'), DeliveryError('Request failed after 5 attempts: <Status.NWK_INVALID_REQUEST: 194>'), DeliveryError('Request failed after 5 attempts: <Status.NWK_INVALID_REQUEST: 194>')]
2023-02-05 20:25:26.492 WARNING (MainThread) [homeassistant.components.zha.core.channels.base] [0xEE50:2:0x0000]: async_initialize: all attempts have failed: [DeliveryError('Request failed after 5 attempts: <Status.NWK_INVALID_REQUEST: 194>'), DeliveryError('Request failed after 5 attempts: <Status.NWK_INVALID_REQUEST: 194>'), DeliveryError('Request failed after 5 attempts: <Status.NWK_INVALID_REQUEST: 194>'), DeliveryError('Request failed after 5 attempts: <Status.NWK_INVALID_REQUEST: 194>')]
2023-02-05 20:25:26.543 WARNING (MainThread) [homeassistant.components.zha.core.channels.base] [0xEE50:1:0x0006]: async_initialize: all attempts have failed: [DeliveryError('Request failed after 5 attempts: <Status.NWK_INVALID_REQUEST: 194>'), DeliveryError('Request failed after 5 attempts: <Status.NWK_INVALID_REQUEST: 194>'), DeliveryError('Request failed after 5 attempts: <Status.NWK_INVALID_REQUEST: 194>'), DeliveryError('Request failed after 5 attempts: <Status.NWK_INVALID_REQUEST: 194>')]
2023-02-05 20:25:28.813 WARNING (MainThread) [homeassistant.components.zha.core.channels.base] [0xEE50:2:0x0406]: async_initialize: all attempts have failed: [DeliveryError('Request failed after 5 attempts: <Status.NWK_INVALID_REQUEST: 194>'), DeliveryError('Request failed after 5 attempts: <Status.NWK_INVALID_REQUEST: 194>'), DeliveryError('Request failed after 5 attempts: <Status.MAC_NO_ACK: 233>'), DeliveryError('Request failed after 5 attempts: <Status.NWK_INVALID_REQUEST: 194>')]
2023-02-05 20:25:28.842 WARNING (MainThread) [homeassistant.components.zha.core.channels.base] [0xEE50:2:0x0001]: async_initialize: all attempts have failed: [DeliveryError('Request failed after 5 attempts: <Status.NWK_INVALID_REQUEST: 194>'), DeliveryError('Request failed after 5 attempts: <Status.MAC_NO_ACK: 233>'), DeliveryError('Request failed after 5 attempts: <Status.NWK_INVALID_REQUEST: 194>'), DeliveryError('Request failed after 5 attempts: <Status.NWK_INVALID_REQUEST: 194>')]
2023-02-05 20:25:54.198 WARNING (MainThread) [homeassistant.components.zha.core.channels.base] [0xEE50:2:0x0402]: async_initialize: all attempts have failed: [TimeoutError(), DeliveryError('Request failed after 5 attempts: <Status.NWK_INVALID_REQUEST: 194>'), DeliveryError('Request failed after 5 attempts: <Status.NWK_INVALID_REQUEST: 194>'), DeliveryError('Request failed after 5 attempts: <Status.NWK_INVALID_REQUEST: 194>')]
2023-02-05 20:27:28.299 WARNING (MainThread) [homeassistant.components.zha.core.channels.base] [0x1F10:1:0x0006]: async_initialize: all attempts have failed: [TimeoutError(), TimeoutError(), TimeoutError(), TimeoutError()]
2023-02-05 20:27:28.716 WARNING (MainThread) [homeassistant.components.zha.core.channels.base] [0x1F10:2:0x0406]: async_initialize: all attempts have failed: [TimeoutError(), TimeoutError(), TimeoutError(), TimeoutError()]
2023-02-05 20:27:28.779 WARNING (MainThread) [homeassistant.components.zha.core.channels.base] [0x1F10:2:0x0001]: async_initialize: all attempts have failed: [TimeoutError(), TimeoutError(), TimeoutError(), TimeoutError()]
2023-02-05 20:27:29.917 WARNING (MainThread) [homeassistant.components.zha.core.channels.base] [0x1F10:2:0x0400]: async_initialize: all attempts have failed: [TimeoutError(), TimeoutError(), TimeoutError(), TimeoutError()]
2023-02-05 20:27:30.187 WARNING (MainThread) [homeassistant.components.zha.core.channels.base] [0x1F10:2:0x0402]: async_initialize: all attempts have failed: [TimeoutError(), TimeoutError(), TimeoutError(), TimeoutError()]
2023-02-05 20:27:30.351 WARNING (MainThread) [homeassistant.components.zha.core.channels.base] [0x1F10:2:0x0000]: async_initialize: all attempts have failed: [TimeoutError(), TimeoutError(), TimeoutError(), TimeoutError()]
2023-02-05 20:29:08.726 WARNING (MainThread) [homeassistant.components.zha.core.channels.base] [0x5D07:11:0x0006]: async_initialize: all attempts have failed: [TimeoutError(), TimeoutError(), TimeoutError(), TimeoutError()]
2023-02-05 20:29:09.522 WARNING (MainThread) [homeassistant.components.zha.core.channels.base] [0xD84B:11:0x0008]: async_initialize: all attempts have failed: [TimeoutError(), TimeoutError(), TimeoutError(), TimeoutError()]
2023-02-05 20:29:09.734 WARNING (MainThread) [homeassistant.components.zha.core.channels.base] [0x5D07:11:0x0008]: async_initialize: all attempts have failed: [TimeoutError(), TimeoutError(), TimeoutError(), TimeoutError()]
2023-02-05 20:29:10.139 WARNING (MainThread) [homeassistant.components.zha.core.channels.base] [0xD84B:11:0x0006]: async_initialize: all attempts have failed: [TimeoutError(), TimeoutError(), TimeoutError(), TimeoutError()]
2023-02-05 20:30:14.492 ERROR (MainThread) [homeassistant.util.logging] Exception in _maybe_force_refresh when dispatching 'zha_light_group_state_changed': ({'entity_ids': ['light.hallway_upstairs_ceiling_2_state', 'light.hallway_upstairs_light_ceiling_1_bulb_3_state', 'light.hallway_upstairs_light_ceiling_1_bulb_1_state']},)
File "/usr/src/homeassistant/homeassistant/components/zha/light.py", line 875, in _maybe_force_refresh
await self.async_get_state()
File "/usr/src/homeassistant/homeassistant/components/zha/light.py", line 807, in async_get_state
results = await self._color_channel.get_attributes(
File "/usr/src/homeassistant/homeassistant/components/zha/core/channels/base.py", line 460, in _get_attributes
read, _ = await self.cluster.read_attributes(
File "/usr/local/lib/python3.10/site-packages/zigpy/zcl/__init__.py", line 471, in read_attributes
result = await self.read_attributes_raw(to_read, manufacturer=manufacturer)
File "/usr/local/lib/python3.10/site-packages/zigpy/zcl/__init__.py", line 324, in request
return await self._endpoint.request(
File "/usr/local/lib/python3.10/site-packages/zigpy/endpoint.py", line 237, in request
return await self.device.request(
File "/usr/local/lib/python3.10/site-packages/zigpy/device.py", line 297, in request
await self._application.request(
File "/usr/local/lib/python3.10/site-packages/zigpy/application.py", line 690, in request
await self.send_packet(
File "/usr/local/lib/python3.10/site-packages/zigpy_znp/zigbee/application.py", line 1026, in send_packet
response = await self._send_request_raw(
File "/usr/local/lib/python3.10/site-packages/zigpy_znp/zigbee/application.py", line 913, in _send_request_raw
self._znp.request_callback_rsp(
AttributeError: 'NoneType' object has no attribute 'request_callback_rsp'
2023-02-05 20:30:14.696 WARNING (MainThread) [homeassistant.components.zha.core.channels.base] [0x1CF5:2:0x0402]: 'async_initialize' stage failed: 'NoneType' object has no attribute 'request_callback_rsp'
2023-02-05 20:30:14.698 WARNING (MainThread) [homeassistant.components.zha.core.channels.base] [0x1CF5:2:0x0406]: 'async_initialize' stage failed: 'NoneType' object has no attribute 'request_callback_rsp'
2023-02-05 20:30:14.700 WARNING (MainThread) [homeassistant.components.zha.core.channels.base] [0x1CF5:2:0x0001]: 'async_initialize' stage failed: 'NoneType' object has no attribute 'request_callback_rsp'
2023-02-05 20:30:14.703 WARNING (MainThread) [homeassistant.components.zha.core.channels.base] [0x1CF5:2:0x0000]: 'async_initialize' stage failed: 'NoneType' object has no attribute 'request_callback_rsp'
2023-02-05 20:30:14.714 WARNING (MainThread) [homeassistant.components.zha.core.channels.base] [0x1CF5:2:0x0400]: 'async_initialize' stage failed: 'NoneType' object has no attribute 'request_callback_rsp'
2023-02-05 20:30:14.719 WARNING (MainThread) [homeassistant.components.zha.core.channels.base] [0x1CF5:1:0x0006]: 'async_initialize' stage failed: 'NoneType' object has no attribute 'request_callback_rsp'
2023-02-05 20:30:16.273 ERROR (MainThread) [homeassistant.components.websocket_api.http.connection] [546906609584] Error handling message: Unknown error (unknown_error) from 192.168.1.105 (Mozilla/5.0 (Windows NT 10.0; rv:106.0) Gecko/20100101 Firefox/106.0)
File "/usr/src/homeassistant/homeassistant/components/websocket_api/decorators.py", line 27, in _handle_async_response
await func(hass, connection, msg)
File "/usr/src/homeassistant/homeassistant/components/zha/api.py", line 1174, in websocket_create_network_backup
backup = await application_controller.backups.create_backup(load_devices=True)
File "/usr/local/lib/python3.10/site-packages/zigpy/backups.py", line 128, in create_backup
await self.app.load_network_info(load_devices=load_devices)
File "/usr/local/lib/python3.10/site-packages/zigpy_znp/zigbee/application.py", line 159, in load_network_info
await self._znp.load_network_info(load_devices=load_devices)
AttributeError: 'NoneType' object has no attribute 'load_network_info'
2023-02-05 20:30:25.056 WARNING (MainThread) [homeassistant.components.zha.core.channels.base] [0x4CFE:1:0xfcc0]: 'async_initialize' stage failed: 'power_outage_memory'
Specs:
Hardware: Raspberry Pi4
Zigbee Stick: SkyConnect 1.0 with firmware SkyConnect_EZSP_v7.1.4.0
OS: HasOS
Having the same problem here. Has anyone made any progress?
Had the exact same problem. Used the link above and reflashed the skyconnct firmware using terminal. ZHA finally came back but no connected devices. Rebooted home assistant then triggered each device and all is working again. I love home assistant and have been using it for years with a tubez zigbee coordinator before migrating to skyconnect. I don’t think they have all the bugs worked out yet?
Ok … A little good … after the flash, the stick is back.
But only with Zigbee … Have anyone try a second flash with the home-assisten GUI to Multi-PAN or in other words, to thread and zigbee?
I got my SkyConnect stick today, connected it to my Pi (with cable) and tried to activate using ZHA integration. This always results in an “unknown error” and the log shows the following:
Logger: aiohttp.server
Source: components/zha/radio_manager.py:137
First occurred: 13:12:23 (7 occurrences)
Last logged: 13:17:26
  File "/usr/local/lib/python3.10/site-packages/aiohttp/web_protocol.py", line 435, in _handle_request
    resp = await request_handler(request)
  File "/usr/local/lib/python3.10/site-packages/aiohttp/web_app.py", line 504, in _handle
    resp = await handler(request)
  File "/usr/local/lib/python3.10/site-packages/aiohttp/web_middlewares.py", line 117, in impl
    return await handler(request)
  File "/usr/src/homeassistant/homeassistant/components/http/security_filter.py", line 60, in security_filter_middleware
  File "/usr/src/homeassistant/homeassistant/components/http/forwarded.py", line 100, in forwarded_middleware
  File "/usr/src/homeassistant/homeassistant/components/http/request_context.py", line 28, in request_context_middleware
  File "/usr/src/homeassistant/homeassistant/components/http/ban.py", line 80, in ban_middleware
  File "/usr/src/homeassistant/homeassistant/components/http/auth.py", line 236, in auth_middleware
  File "/usr/src/homeassistant/homeassistant/components/http/view.py", line 145, in handle
    result = await result
  File "/usr/src/homeassistant/homeassistant/components/config/config_entries.py", line 180, in post
    return await super().post(request, flow_id)
  File "/usr/src/homeassistant/homeassistant/components/http/data_validator.py", line 72, in wrapper
    result = await method(view, request, data, *args, **kwargs)
  File "/usr/src/homeassistant/homeassistant/helpers/data_entry_flow.py", line 110, in post
    result = await self._flow_mgr.async_configure(flow_id, data)
  File "/usr/src/homeassistant/homeassistant/data_entry_flow.py", line 253, in async_configure
    result = await self._async_handle_step(
  File "/usr/src/homeassistant/homeassistant/data_entry_flow.py", line 335, in _async_handle_step
    result: FlowResult = await getattr(flow, method)(user_input)
  File "/usr/src/homeassistant/homeassistant/components/zha/config_flow.py", line 478, in async_step_confirm
    return await self.async_step_choose_formation_strategy()
  File "/usr/src/homeassistant/homeassistant/components/zha/config_flow.py", line 255, in async_step_choose_formation_strategy
    await self._radio_mgr.async_load_network_settings()
  File "/usr/src/homeassistant/homeassistant/components/zha/radio_manager.py", line 193, in async_load_network_settings
    async with self._connect_zigpy_app() as app:
  File "/usr/local/lib/python3.10/contextlib.py", line 199, in __aenter__
    return await anext(self.gen)
  File "/usr/src/homeassistant/homeassistant/components/zha/radio_manager.py", line 137, in _connect_zigpy_app
    await app.connect()
  File "/usr/local/lib/python3.10/site-packages/bellows/zigbee/application.py", line 124, in connect
    self._ezsp = await bellows.ezsp.EZSP.initialize(self.config)
  File "/usr/local/lib/python3.10/site-packages/bellows/ezsp/__init__.py", line 101, in initialize
    await ezsp.connect(use_thread=zigpy_config[conf.CONF_USE_THREAD])
  File "/usr/local/lib/python3.10/site-packages/bellows/ezsp/__init__.py", line 118, in connect
    self._gw = await bellows.uart.connect(self._config, self, use_thread=use_thread)
  File "/usr/local/lib/python3.10/site-packages/bellows/uart.py", line 396, in connect
    protocol, connection_done = await thread.run_coroutine_threadsafe(
  File "/usr/local/lib/python3.10/site-packages/bellows/uart.py", line 375, in _connect
    transport, protocol = await zigpy.serial.create_serial_connection(
  File "/usr/local/lib/python3.10/site-packages/zigpy/serial.py", line 36, in create_serial_connection
    transport, protocol = await loop.create_connection(
  File "/usr/local/lib/python3.10/asyncio/base_events.py", line 1064, in create_connection
    raise exceptions[0]
  File "/usr/local/lib/python3.10/asyncio/base_events.py", line 1049, in create_connection
    sock = await self._connect_sock(
  File "/usr/local/lib/python3.10/asyncio/base_events.py", line 960, in _connect_sock
    await self.sock_connect(sock, address)
  File "/usr/local/lib/python3.10/asyncio/selector_events.py", line 500, in sock_connect
    return await fut
  File "/usr/local/lib/python3.10/asyncio/selector_events.py", line 535, in _sock_connect_cb
    raise OSError(err, f'Connect call failed {address}')
ConnectionRefusedError: [Errno 111] Connect call failed ('172.30.32.1', 9999)
Any solution ?
Had the same problem when I tried the MultiPAN upgrade using the GUI. So I took the following steps and reflashed as described here:
  • disabled ZHA, Thread and OpenThreadRouter integrations
  • uninstalled the MultiPAN addon
  • flashed back to 7.1.1 Zigbee only FW
  • rebooted (just to be sure :wink:)
  • reconfigured ZHA and kept config
Works like before, but scared the crap out of me when it wouldn’t start after the initial flash to MultiPAN :grinning_face_with_smiling_eyes:
Thanks for assisting ! I got it flashed back to Zigbee only. Now other issues appear.
The stick is recognized under system/hardware but trying to install zha integration it runs into an error.
ZHA integration recognizes the stick, I can choose it, can choose the radio type (ezsp) but with the next step after choosing the device port (I took the whole path : “/dev/serial/by-id/usb-…-if00-port0”) and setting baurate to 115200 it runs into an error:
Any Idea ?
Join the discussion, have the same problems. Is there already a GitHub bug to track and possibly a solution to the problem?
Damn it, not working on my end :frowning:
When you say “7.1.1 Zigbee only FW” do you mean “EmberZNet/NabuCasa_SkyConnect_EZSP_v7.1.1.0_ncp-uart-hw_115200.gbl”?
yes exactly, that one worked for me. Are you stuck flashing or in the re-setup afterwards?
Anyone make a second try to flash the multiprotocol?
Just want to run through my experience so far switching to Multi-PAN, nearly there I’d say but here goes…
I was originally using SkyConnect to handle ZHA directly (HA: 2023.3.0b0). Backed up, deleted the Device from HA.
Flashed to multiprotocol firmware 4.2.1 was successful via Skyconnect firmware update page (ensure you have the drivers installed as specified).
Plugged everything back in, proceeded to add the Silicon Labs Multiprotocol add-on and selected SkyConnect & ensured baudrate was 115200. Disable the auto-firmware update as well, as this can stop SLM starting up.
I also have the following enabled:
  • Hardware flow control
  • Co-processor communication tracing
  • Enable OpenThread Border Router
  • Enable OpenThread Border Router web interface
I did have some weirdness with the ports so just overrode the ports with whatever is meant to be set:
  • EZSP Port: 9999
  • OpenThread REST API Port: 8081
Startup successful, now back to re-adding ZHA. Per the instructions you need to match the hostname (in my case it was just “core-silabs-multiprotocol” and formatted the URL to “socket://core-silabs-multiprotocol:9999”). It then picked up on ZHA, restored my backup and most devices came back just fine.
Aside from this, my Aqara Motion Sensors work fine – but magnet sensors & vibration sensors are playing up slightly. When attempting to remove & re-add the device, it doesn’t pick up at all (this is where I’m stuck at the moment).
And all working now! Just Aqara being Aqara as usual when resetting :slight_smile:
Yeah! This also worked for me. Zigbee is up and running again.
Quite honestly, unless it is on a test system, I would not use Multi-PAN support. The Nabu Casa / Home Assistant team are quite clear in saying it is still experimental. If you need Thread devices, which is the only reasons you would attempt Multi-PAN, then use an external border router like the ones from Apple, Google or Amazon.
If you don’t need Thread or have no Thread devices, then running multi-pan is a waste of time and even if it does work, it will result in lower performance on the network as the radio is shared between thread and zigbee, even if no thread devices exist.
@zenstrukt
I’ve actually never had any issue with any of my 30 Aqara devices. They always pair 100% perfectly, whether from new or a re-pair. What are the issues you have with them? I know that is off topic for this thread, but I am curious.
Often times it would take a few goes to work, in this instance pulling out the battery for a period of time and trying the process again got it sorted (after a few attempts) and I was able to pair it. I know with the pairing process it needs to be precise :slight_smile:
If I ever have issues I’ll keep that in mind.
I know I have to remember with Aqara that they don’t like pairing via another router, so have to take the sensors down and pair them right beside the HA coordinator, but that is listed in the pairing process for the devices in the Aqara documentation.
Thanks for the extra information. It will be good to keep that in mind if I have issues in the future :slightly_smiling_face:
