My ZHA now unworking. Did the same as @rosshenning as I found nothing but issues with 2023.6.0. Going back to 5.4 has only caused more issues. Now I figure I have to move forward and try and fix the new issues somehow.
I tried something different to @Slaut, I tried to re-add the usb device-by-id that I had previously configured for my Skyconnect device in the Silicon labs multiprotocol addon config, by adding it through yaml config. The only usb options available in the dropdown are /dev device names and I had issues with this in the past. The new usb-by-deviceid setting sticks but doesn’t show in the UI.
Logs look mainly OK but get a lot of “can’t connect, seems unresponsive” and of course I can’t load ZHA as there is nothing for ZHA to connect to.
I’m stumped.
** edit:
I’m now unable to access the ZHA integration, it won’t load and so doesn’t show for me to be able to change config. Way to go config-flow!
I see these in logs:
13:11:53 – (ERROR) config_entries.py
Error occurred loading flow for integration zha: Exception importing homeassistant.components.zha.config_flow
Unexpected exception importing component homeassistant.components.zha
13:11:53 – (ERROR) components/zha/core/const.py - message first occurred at 13:10:58 and shows up 3 times
