I have a Skyconnect v1.0 dongle on my Intel NUC. Using ZHA. After each reboot of the system the ZHA integration doesn’t load. The error states that the Zigbee coördinator is running a multi protocol firmware. I then go the System → Hardware → Home Assistant Skyconnect → Configure. Then select the Zigbee firmware. The flasher is downloaded automatically, Zigbee firmware installed and I can restart ZHA no issue. But why do I need to do this after each reboot? It seems the system doesn’t see the latest installed firmware. Side note: so now my HA is up and running. If I now go to System → Hardware → Home Assistant Skyconnect I have the button “configure” only. It then does its usual thing and says: Pick your firmware
Let’s get started with setting up your Home Assistant SkyConnect. Do you want to use it to set up a Zigbee or Thread network?
Any help please?
