Sleep example code from documentation not working?
Hi there :slight_smile:
On this page, about half way down, there is an example that shows how to make the device sleep once a certain condition is met: Deep Sleep Component — ESPHome
It looks like this:
on_...:
  then:
    - deep_sleep.enter:
        sleep_duration: 20min
When I do the same it looks like this in my code (my entire code is below):
    on_value_range:
      above: 100
      below: 100000000000
      then:
        - deep_sleep.enter:
        sleep_duration: 1min
This gets me this error in the editor:
“unable to find action with the name deep_sleep.enter”
Why is this? I practically copy pasted this from the documentation…
The goal is to get the ESP to sleep once the pulse-counter output reaches a certain threshold. It’s for a greenhouse watering device.
The entire code looks like this:
esphome:
esp8266:
  board: nodemcuv2
# Enable logging
logger:
# Enable Home Assistant API
api:
  encryption:
    key: "some key"
ota:
  password: "...some pw"
wifi:
  ssid: !secret wifi_ssid
#  ap:
#    ssid: "Vanding2 Fallback Hotspot"
#    password: "fallback pw"
captive_portal:
    #kontakter start
switch:
  - platform: gpio
    pin: D3
  - platform: gpio
    pin: D4
cover:
    open_action:
      # Cancel any previous action
      - switch.turn_off: close_switch
      # Turn the OPEN switch on briefly
      - switch.turn_on: open_switch
      - delay: 0.1s
      - switch.turn_off: open_switch
    close_action:
      - switch.turn_on: close_switch
      - delay: 0.1s
    stop_action:
    optimistic: true
    assumed_state: true
    #kontakter slut
  - platform: pulse_meter
    pin: D6
    unit_of_measurement: 'Liter'
    internal_filter: 100ms
    internal_filter_mode: "PULSE"
    accuracy_decimals: 3
    filters:
      - multiply: 1.0
    on_value_range:
      above: 100
      below: 100000000000
      then:
        - deep_sleep.enter:
    total:
      unit_of_measurement: "Liter"
      filters:
        - multiply: 1.00
I haven’t used it before, but I think your esphome yaml is missing the deep_sleep component and (optional) run_duration and id definitions:
deep_sleep:
  run_duration: 10s
The “deep_sleep:” block should be entered at the same (top) level as wifi, ota, captive_portal, etc.
does not look like
look at your indentation
Thanks, but I tried both prior to posting (and again just now). It doesn’t really change much. Also the error is tied to the function call (so the line just before the ones you point to.
So I messed around with it a bit more, and in case anyone wants to know (future readers perhaps) both Nickrout and gonzotek answers has to be used in combination:
So the correct way of doing it appears to be
Top of code:
deep_sleep:
(no other params are used here since we want to trigger the sleep somewhere else)
When sleep is to be triggered, use the code from Nickrouts answer.
