Sleep Number Bed Integration - Authentication
Not sure if I missed it in the update. But my Sleep number auth details are in config.yaml. Since 2006.9 It has been registering as a daily fix for me to put the password for sleepiq into the front end and it works for another day. Did they move it to force the integration out of config.yaml, or is something up. All I can find in the GitHub is something that looks like an AI automation fix submission, but haven’t found any details on what is going on… Anyone else know about this, or have a link to what I probably missed?
Seems like the same issue? SleepNumber Integration keeps needing the password entered · Issue #181777 · home-assistant/core · GitHub
Thank you! That’s the same one. I searched but probably didn’t use the correct terms…
Now having the same issue using the API key with Unifi… :slight_smile:
Create a new thread, specify where you are stuck and what you have tried and people will help :slight_smile:
