Slide gate setup
Hello guys. I have a slide gate outside. No physical buttons in garage or elsewhere, just a remote (with rolling codes). Gate motor is BFT.
What is the best way to approach this to implement it into home assistant? I have read about ESP8266 relays, but the information I found was not sufficent, plus it basically requires to change the motherboard of the gate motor.
Any help is very much appreciated.
You could solder some wires to the remote buttons, and control those with relays to open/close the port.
Are you sure it is rolling codes?
If it is really rolling codes, to hack it is not impossible but hard…
First check out if the manufacturer has a gateway/hub for this setup.
I guess the best would be to to as @devastator suggested; if there is no buttons on the receiver, you can solder wires to remote buttons. Also, check this out to give you an idea: https://www.instructables.com/id/How-to-Connect-Your-Somfy-Remote-to-Alexa-With-an-/
As devastator said. Works a treat.
Any tutorials on that I could read / watch? I am not too familiar with wiring :slight_smile:
On aliexpress you can find single/dual/quad/… relay boards for cheap. Pick one of those, and hook it up to e.g. a D1 mini.
Open up the remote and solder 1 wire on each side of the button. So every button will have 2 wires. Attach the 2 wires to a relay. and repeat the process for the other buttons :slight_smile:
So in this scenario it would function as a remote, which means, if the signal is strong enough, I can use it inside of my house, instead of building it in the gate motor?
Exactly.
Do you have a switch on the inside of the house to control your fence ?
No, like I said in the original post, no physical switches inside/outside of any kind, just a remote.
Than this would be the way to go, unless you want to open the control board of your gate to see if it has contacts for opening/closing the gate.
This makes sense, however, I am probably not gonna do this, because it seems very difficult, especially with little to none wiring experience and no tutorials to help me. Anyway, thank you so much for your help, atleast now I have the idea how it would work. Have a nice day!
It is not that difficult… Where are you from ?
Lithuania, why?
Otherwise I could make it and send it too you, but I’m from Belgium.
It is not legal to ship these abroad for you or why cant you?
Shipping costs :slight_smile:
I bet its under 10 euros :slight_smile:
