If youâre new to HA you should try to learn the basics before getting into modding cards etc. It takes a lot of fiddling to get things like customising card sizes right.
If you really want to control size and placement of cards, play around with custom:layout-card for a bit. You can set width and height of columns and rows and that will cause cards to fit in to the spaces. The grid layout is best for that but comes with its own headaches.
I just need you to write an example for me with my entity i send you , so I can understand and copy for other cards.
i no understand because in card edit no regulation equal card so no change size in lovelace.
thx you
Thatâs expected. It means you canât use the visual editor, because you are using options which it does not support, such as type: custom:slider-entity-row.
I think the fact that the visual editor cannot be used should be stated in README.md and the resulting GitHub page (github.com/thomasloven/lovelace-slider-entity-row)? Iâve wasted much time because it is not. Also why isnât there a slider in the Lovelace UI? Sliders are basic and this seems a big oversight.
It is possible to use the slider-entity-row as a vertical slider?
I am using it to control a camera moment. it would be great to have an vertical otpion
Believe or not, when I was asking for it I was thinking about haw idiot it sounds. But let me give you an idea of what I intent use it for control the camera moment:
sorry, but I am relative new especially to custom cards.
can someone give an example how to add a cover and a climate please (as the picture below)
I have added some lights but I am stuck with covers
