I have a template number slider in Home Assistant, but the slider value is not being correctly assigned to the “power” variable. Despite using the id(light_power).state to capture the value, it seems like the value isn’t being properly written or passed in the code. I am trying to send the value through SPI, but it doesn’t seem to reflect the slider’s current state. Any help with debugging this issue would be appreciated.
When I define the “power” variable with a static value (e.g., power = 50), I can measure the value correctly on the bus. However, when I move the slider on the dashboard, the action is triggered, but the slider value is not written to the “power” variable. I would be happy, if someone could give me a hint. I am new to YAML and HA.
Here’s my code:
esphome:
friendly_name: growlight
esp32:
board: esp32-c3-devkitm-1
framework:
type: esp-idf
# Enable logging
logger:
# Enable Home Assistant API
api:
encryption:
key: "removed for the post"
ota:
- platform: esphome
password: "removed for the post"
wifi:
ssid: !secret wifi_ssid
ap:
ssid: "removed for the post"
captive_portal:
# Example configuration entry
switch:
- platform: gpio
pin: GPIO3
restore_mode: RESTORE_DEFAULT_ON
# SPI-Bus-Konfiguration
spi:
clk_pin: GPIO6
mosi_pin: GPIO7
miso_pin: GPIO2
# SPI-Gerät (BH2226FV-E2)
spi_device:
cs_pin: GPIO10
data_rate: 1MHz
spi_mode: 3
bit_order: msb_first
# Number-Slider für Home Assistant
number:
min_value: 0
max_value: 200
step: 1
icon: "mdi:slider"
set_action:
- lambda: |-
uint16_t power = (uint16_t)id(light_power).state; // Slider-Wert als 16-Bit-Zahl
uint16_t channel8 = 0x0008; // Beispielwert für channel8
auto reverse = [](uint8_t in) -> uint8_t {
uint8_t out = 0;
if (in & 0x01) out |= 0x80;
if (in & 0x02) out |= 0x40;
if (in & 0x04) out |= 0x20;
if (in & 0x08) out |= 0x10;
if (in & 0x10) out |= 0x08;
if (in & 0x20) out |= 0x04;
if (in & 0x40) out |= 0x02;
if (in & 0x80) out |= 0x01;
return out;
uint16_t channel = channel8 & 0x000F; // Nur untere 4 Bits behalten
channel = reverse(channel); // Bits umkehren
channel = channel << 4; // Links schieben um 4 Bits
uint16_t buff = channel | power; // `channel` mit `power` verknüpfen
ESP_LOGD("slider", "Aktueller Wert des Sliders: %f", id(light_power).state);
uint16_t powerDownRelease = 0x0900;
uint16_t selectDA = 0x03FF;
uint16_t statusSet = 0x0FFF;
// Funktion zum Senden eines 16-Bit-Werts per SPI
auto send_spi = [](uint16_t data) {
uint8_t high_byte = (data >> 8) & 0xFF;
uint8_t low_byte = data & 0xFF;
id(bh2226).enable(); // CS auf LOW
id(bh2226).write_byte(high_byte);
id(bh2226).write_byte(low_byte);
id(bh2226).disable(); // CS auf HIGH
// Sende die SPI-Befehle
send_spi(powerDownRelease);
send_spi(selectDA);
send_spi(statusSet);
send_spi(buff); // Letzte Nachricht mit dem berechneten Wert senden
Here’s the slider on my dashboard:
