Greetings
Anyone has an idea why the item in HA is not updated by the slider widget in ESPHome? Vice verse is working fine, when I change the value in HA, the slider in the lvgl display is updated.
Config:
number:
- id: current
platform: homeassistant
entity_id: number.warp2_global_current
on_value:
- lvgl.slider.update:
value: !lambda return x;
lvgl:
widgets:
- slider:
x: 45
y: 168
width: 240
height: 30
min_value: 6
max_value: 16
on_change:
- number.set:
Logs:
[17:37:37][D][api.connection:2440]: Home Assistant 2026.3.4 (10.0.72.20): connected
[17:37:37][D][homeassistant.number:023]: 'number.warp2_global_current': Got state 14.0
[17:37:37][D][number:025]: 'current' >> 14.00
[17:37:37][D][homeassistant.number:033]: 'current': Min retrieved: 6.0
[17:37:37][D][homeassistant.number:043]: 'current': Max retrieved: 16.0
[17:37:37][D][homeassistant.number:053]: 'current': Step Retrieved 1.0
[17:37:42][D][xpt2046:055]: Touchscreen Update [2794, 1345], z = 2399
[17:37:42][D][xpt2046:055]: Touchscreen Update [2789, 1344], z = 2462
[17:37:42][D][xpt2046:055]: Touchscreen Update [2787, 1346], z = 2413
[17:37:42][D][number:064]: 'current': Setting value
[17:37:42][D][number:123]: New value: 8.000000
[17:37:43][D][number:025]: 'current' >> 8.00
[17:37:43][D][xpt2046:055]: Touchscreen Update [2797, 1344], z = 2311
I tried different actions like on_value, on_change, on_release in the widget, negative. In the log example, the value in HA is 14. When I move the slider in the lvgl display to 8, the value is not updated in HA.
