Hello all!
I recently moved my configuration from a VM image (that was also moved from a Pi based image) to a NUC with the provided NUC image. Everything appears to be working well except for a few WLED errors in the logs. However, system reboots and shutdowns take 5+ minutes to be performed. Startups take a couple of minutes, which is also a bit longer than expected but not bad.
The NUC I’m using is a 5th gen celeron with 8GB of RAM and 230GB of SSD Disk - not a terribly fast system but certainly faster than the Pi 3 that had formally hosted the same configuration and would reboot in 1min 30sec.
Looking at the Host and System logs, I don’t see any errors listed per-say but if there is a hangup and subsequent timeout, I don’t see that either. I could use some advice on things to look for or some checks that I may be overlooking.
Again, the system is working fine when up but seems to take abnormally long to shutdown/restart. (5+ minutes)
System Health
version: 2021.1.4
installation_type: Home Assistant OS
dev: false
hassio: true
docker: true
virtualenv: false
python_version: 3.8.7
os_name: Linux
os_version: 5.4.86
arch: x86_64
timezone: America/Chicago
host_os: Home Assistant OS 5.10
update_channel: stable
supervisor_version: 2021.01.5
docker_version: 19.03.13
disk_total: 228.5 GB
disk_used: 4.8 GB
healthy: true
supported: true
board: intel-nuc
supervisor_api: ok
version_api: ok
installed_addons: Samba share (9.3.0), Mosquitto broker (5.1), TasmoAdmin (0.13.1), Duck DNS (1.12.4), MariaDB (2.2.1), Terminal & SSH (8.10.0), Check Home Assistant configuration (3.6.0), Grocy (0.9.2), ESPHome (1.15.3), Node-RED (7.2.11)
dashboards: 3
mode: storage
resources: 0
