SLZB-06 and Hue lights
I have been trying to use some new Hue light bulbs in BLE mode. They get noticed in Devices but I can’t get then working in BLE mode. My Beelink mini PC supports Bluetooth on its own and I have a ESP32 with Bluetooth proxy setup. After many attempts I got each of the 2 bulbs added (at separate times) but they won’t stay working more than a few hours.
Meanwhile I have a SLZB-06 connected to my wired LAN doing nothing. These lights are supposed to work by BLE or Zigbee. To get them working by Zigbee, do I need to change the configuration of the SLZB-06? Currently it is in the role of Zigbee Coordinator. Bluetooth proxy is available but not enabled. The device is not close to those lamps.
How should I approach using the Hue lamps in a Zigbee network?
I figured it out. After doing a factory reset on the lights that had been originally det up via BLE, the Zigbee coordinator was able to discover them.
