SLZB-06 'Failed setup' after update to v3.3.3.dev7, all Zigbee devices non-functioning!
I updated my SLZB-06 Zigbee controller to v3.3.3.dev7 this morning. None of the devices are available now. Under Settings > Devices > Zigbee Home Automation it shows Failed setup, will retry, and it is continually retrying setup and failing again every minute or so. If I click Check the logs it takes me to a log search for zha with the result No issues found for search term 'zha'
Navigating to Settings > Zigbee shows what you see in the screenshot. Almost everything in my house is Zigbee so currently my whole house is down! Can anyone help me with some troubleshooting? Thanks a ton!
Ok, crisis averted, apparently I just had to manually power cycle the SLZB-06 by removing its POE cable and now everything works again. Restarting HA and Restarting the controller via the HA interface did not work for anyone else who runs across this.
Had the same, it appeared it was some sort of error dev was advertised as an update while i was not on the dev channel. Downgraded and it worked again.
Installing Development versions can be a dicey move...
I just install the updates HA recommends, I set everything to 'Stable' anywhere I can.
Second time this has happened this month. It happened before with 3.3.3.dev1.
HA is simply informing you of updates available on the stable branch. Someone needs to reach out to SMLight & tell them flag their releases properly & to add an opt-in option for their beta releases.
