After doing Zigbee Coordinator OTA update - 20240710 for SLZB-06 my Z2M Configuration is broken and Z2M wont start anymore.
I am lost searching for the cause and was hoping somebody could give me a hint to fix this and get Z2M up and running again!
Starting Zigbee2MQTT without watchdog.
[2025-03-25 20:34:01] error: z2m: Error while starting zigbee-herdsman
[2025-03-25 20:34:01] error: z2m: Failed to start zigbee-herdsman
[2025-03-25 20:34:01] error: z2m: Check Zigbee2MQTT fails to start/crashes runtime | Zigbee2MQTT for possible solutions
[2025-03-25 20:34:01] error: z2m: Exiting…
[2025-03-25 20:34:01] error: z2m: Error: network commissioning timed out - most likely network with the same panId or extendedPanId already exists nearby (Error: AREQ - ZDO - stateChangeInd after 60000ms
Perhaps this could be a solution for you: (Its for the new test firmware, but who knows)
In the end I was able to restore everything by downgrading firmwares, shutting down Z2M addon, and manually restoring all the files in homeassistant/zigbee2mqtt from previous automatic backup. Files included configuration.yaml, coordinator_backup.json, database.db and state.json. The restart Z2M and everything was back.
If not, the best place to get specific help may be there also , i think.
