just got 2 SLZB-06 updated their firmware and connected both to network, have 1 running in coordinator mode which i got working with Z2M and added 2 devices. we have a fairly large home with lots of insulation between floors that cause wifi/signal issues so i thought to avoid that altogether get 1 for each floor. i have the 2nd in router mode but i’m not sure if that’s it or if i need to add it to the coordinator also? i see it when i reconnect but it doesn’t add all the details and says unsupported. is that it or is there more to the router part or is it even needed in HA?
Hello surbin004,
2 devices does not a good zigbee mesh make.
Here is a bunch of posts that might help you get your Zigbee going.
