Hey
SLZB-06M POE - After upgrading from 2.7.1 General & Radio revision: 20240710 to latest versions, Z2M devices is not working. I have every backup.
This is the logs from Z2M
Any advise ?
Those are my Z2M configuration ( I don’t think the first section was there before the update )
data_path: /config/zigbee2mqtt
socat:
enabled: false
master: pty,raw,echo=0,link=/tmp/ttyZ2M,mode=777
slave: tcp-listen:8485,keepalive,nodelay,reuseaddr,keepidle=1,keepintvl=1,keepcnt=5
options: "-d -d"
log: false
mqtt: {}
serial:
port: tcp://10.0.13.1:6638
baudrate: 115200
adapter: zstack
This is the logs ( last 2 errors is the example when trying to change llight switch )
[20:09:15] INFO: Preparing to start...
[20:09:15] INFO: Socat not enabled
[20:09:16] INFO: Starting Zigbee2MQTT...
Starting Zigbee2MQTT without watchdog.
[2025-11-11 20:09:17] info: z2m: Logging to console, file (filename: log.log)
[2025-11-11 20:09:17] info: z2m: Starting Zigbee2MQTT version 2.6.3 (commit #unknown)
[2025-11-11 20:09:17] info: z2m: Starting zigbee-herdsman (6.3.2)
[2025-11-11 20:09:17] info: zh:zstack:znp: Opening TCP socket with 10.0.13.1:6638
[2025-11-11 20:09:17] info: zh:zstack:znp: Socket connected
[2025-11-11 20:09:17] info: zh:zstack:znp: Socket ready
[2025-11-11 20:09:17] info: zh:zstack:znp: Writing CC2530/CC2531 skip bootloader payload
[2025-11-11 20:09:18] info: zh:zstack:znp: Skip bootloader for CC2652/CC1352
[2025-11-11 20:09:19] info: z2m: zigbee-herdsman started (resumed)
[2025-11-11 20:09:19] info: z2m: Coordinator firmware version: '{"meta":{"maintrel":1,"majorrel":2,"minorrel":7,"product":1,"revision":20250325,"transportrev":2},"type":"ZStack3x0"}'
[2025-11-11 20:09:19] info: z2m: Living Room Light (0xa4c138a2ad81bd63): TS0011 - Tuya Smart light switch - 1 gang (EndDevice)
[2025-11-11 20:09:19] info: z2m: AC Smart Relay (0x385b44fffe95d7a5): TO-Q-SY1-JZT - Tongou Din smart relay (with power monitoring via polling) (Router)
[2025-11-11 20:09:19] info: z2m: Main Power Meter (0xa4c1383c6e04d6ca): DAC2161C - MatSee Plus Smart Zigbee energy meter 80A din rail (Router)
[2025-11-11 20:09:19] info: z2m: Bedroom Light (0xa4c138c66d01caf5): TS0011 - Tuya Smart light switch - 1 gang (EndDevice)
[2025-11-11 20:09:19] info: z2m: Entrance Switch (0xa4c138faf1392a07): TS0012 - Tuya Smart light switch - 2 gang (EndDevice)
[2025-11-11 20:09:19] info: z2m: Kitchen Gas Detector (0xa4c138585f8b2090): TS0601_gas_sensor_4 - Tuya Gas sensor (Router)
[2025-11-11 20:09:19] info: z2m: Kitchen Water Sensor (0xa4c138ddf5c5e050): SW02 - Meian Water leak sensor (EndDevice)
[2025-11-11 20:09:19] info: z2m: Kitchen Smoke Detector (0xa4c138f8f73c1f26): TS0601_smoke_6 - Tuya Smoke sensor (EndDevice)
[2025-11-11 20:09:19] info: z2m: Living Room Smoke Detector (0xa4c1388574fab3b7): TS0601_smoke_6 - Tuya Smoke sensor (EndDevice)
[2025-11-11 20:09:19] info: z2m: Balcony Light (0xa4c138e63fa86f16): TS0011 - Tuya Smart light switch - 1 gang (EndDevice)
[2025-11-11 20:09:19] info: z2m: Balcony Window (0xa4c1389f993c287f): TS130F - Tuya Curtain/blind switch (Router)
[2025-11-11 20:09:19] info: z2m: LED Bar Switch (0xa4c138cddb4dffa1): TS0013 - Tuya Smart light switch - 3 gang without neutral wire (EndDevice)
[2025-11-11 20:09:19] info: z2m: Corridor Light (0xa4c138364a48266d): TS0011 - Tuya Smart light switch - 1 gang (EndDevice)
[2025-11-11 20:09:19] info: z2m: Bathroom Water Sensor (0xa4c138ea32b4bfa9): SW02 - Meian Water leak sensor (EndDevice)
[2025-11-11 20:09:19] info: z2m: Bathroom Light (0xa4c1380e50336398): TS0011 - Tuya Smart light switch - 1 gang (EndDevice)
[2025-11-11 20:09:19] info: z2m: Safe Room Light (0xa4c138745905bc80): TS0011 - Tuya Smart light switch - 1 gang (EndDevice)
[2025-11-11 20:09:19] info: z2m: Laundry Water Sensor (0xa4c1382fe191f552): SW02 - Meian Water leak sensor (EndDevice)
[2025-11-11 20:09:19] info: z2m: Laundry Smoke Detector (0xa4c138a0f03652d6): TS0601_smoke_6 - Tuya Smoke sensor (EndDevice)
[2025-11-11 20:09:19] info: z2m: Shower Light (0xa4c1382dac660a6d): TS0011 - Tuya Smart light switch - 1 gang (EndDevice)
[2025-11-11 20:09:19] info: z2m: Bedroom Smoke Detector (0xa4c138c04096dab6): TS0601_smoke_6 - Tuya Smoke sensor (EndDevice)
[2025-11-11 20:09:19] info: z2m: Bedroom Socket (0x003c84fffe8ca64d): TS011F_plug_3 - Tuya Smart plug (with power monitoring by polling) (Router)
[2025-11-11 20:09:19] info: z2m: UPS Network Socket (0x003c84fffe9053d9): TS011F_plug_3 - Tuya Smart plug (with power monitoring by polling) (Router)
[2025-11-11 20:09:19] info: z2m: Safe Room Smoke Detector (0xa4c138693b7a4e75): TS0601_smoke_6 - Tuya Smoke sensor (EndDevice)
[2025-11-11 20:09:19] info: z2m: Shower Water Sensor (0xa4c138247f7004d3): SW02 - Meian Water leak sensor (EndDevice)
[2025-11-11 20:09:19] info: z2m: Kitchen LED (0xa4c13891756eff0c): TS0501B - Tuya Zigbee light (Router)
[2025-11-11 20:09:19] info: z2m: Refrigerator Socket (0x003c84fffe8c9516): TS011F_plug_3 - Tuya Smart plug (with power monitoring by polling) (Router)
[2025-11-11 20:09:19] info: z2m: Main Network Switch (0xa4c1383cede1e291): TS011F_plug_1 - Tuya Smart plug (with power monitoring) (Router)
[2025-11-11 20:09:19] info: z2m: Living Room Socket (0x003c84fffe85b52f): TS011F_plug_3 - Tuya Smart plug (with power monitoring by polling) (Router)
[2025-11-11 20:09:19] info: z2m: Boiler Switch (0xa4c13861f0411195): TS0001_switch_1_gang - Tuya 1-Gang switch with backlight (Router)
[2025-11-11 20:09:19] info: z2m: Kitchen Switch (0xa4c138f1d8539d05): TS0012 - Tuya Smart light switch - 2 gang (EndDevice)
[2025-11-11 20:09:19] info: z2m: Living Room Temperature Sensor (0xa4c138dc30bfc541): TH01 - Zbeacon Temperature and humidity sensor (EndDevice)
[2025-11-11 20:09:19] info: z2m: Kitchen Temperature Sensor (0xa4c1389aea787450): TH01 - Zbeacon Temperature and humidity sensor (EndDevice)
[2025-11-11 20:09:19] info: z2m: Safe Room Temperature Sensor (0xa4c138dbb6b3dd08): TH01 - Zbeacon Temperature and humidity sensor (EndDevice)
[2025-11-11 20:09:19] info: z2m: Bedroom Temperature Sensor (0xa4c138dc4dafdfa4): TH01 - Zbeacon Temperature and humidity sensor (EndDevice)
[2025-11-11 20:09:19] info: z2m: Network Cabinet Temperature Sensor (0xa4c1384b240ead47): TH01 - Zbeacon Temperature and humidity sensor (EndDevice)
[2025-11-11 20:09:19] info: z2m: Bathroom Temperature Sensor (0xa4c138f29dc09254): TH01 - Zbeacon Temperature and humidity sensor (EndDevice)
[2025-11-11 20:09:19] info: z2m: Currently 36 devices are joined.
[2025-11-11 20:09:19] info: z2m: Connecting to MQTT server at mqtt://core-mosquitto:1883
[2025-11-11 20:09:19] info: z2m: Connected to MQTT server
[2025-11-11 20:09:19] info: z2m:mqtt: MQTT publish: topic 'zigbee2mqtt/bridge/state', payload '{"state":"online"}'
[2025-11-11 20:09:19] info: z2m: Started frontend on port 8099
[2025-11-11 20:09:19] info: z2m:mqtt: MQTT publish: topic 'zigbee2mqtt/Living Room Light', payload '{"backlight_mode":"normal","linkquality":87,"power_on_behavior":"previous","state":"OFF"}'
[2025-11-11 20:09:19] info: z2m:mqtt: MQTT publish: topic 'zigbee2mqtt/AC Smart Relay', payload '{"current":0.26,"energy":6370.09,"indicator_mode":null,"linkquality":236,"power":35,"power_outage_memory":null,"state":"ON","update":{"installed_version":67,"latest_version":67,"state":"idle"},"voltage":224}'
[2025-11-11 20:09:19] info: z2m:mqtt: MQTT publish: topic 'zigbee2mqtt/Main Power Meter', payload '{"clear_fault":null,"current":5.61,"energy":19233.81,"fault":"over_current_threshold","linkquality":40,"meter_id":"23233750","power":1207,"state":"ON","threshold_1":"over_current_threshold","threshold_1_protection":"OFF","threshold_1_value":50,"threshold_2":null,"threshold_2_protection":null,"threshold_2_value":0,"voltage":224.3}'
[2025-11-11 20:09:19] info: z2m:mqtt: MQTT publish: topic 'zigbee2mqtt/Bedroom Light', payload '{"backlight_mode":"normal","linkquality":83,"power_on_behavior":"previous","state":"OFF"}'
[2025-11-11 20:09:19] info: z2m:mqtt: MQTT publish: topic 'zigbee2mqtt/Entrance Switch', payload '{"backlight_mode":"normal","linkquality":47,"power_on_behavior":null,"power_on_behavior_left":"previous","state_left":"ON","state_right":"ON"}'
[2025-11-11 20:09:19] info: z2m:mqtt: MQTT publish: topic 'zigbee2mqtt/Kitchen Gas Detector', payload '{"alarm_switch":false,"fault_alarm":false,"gas":false,"gas_value":null,"linkquality":58,"preheat":false,"silence":false}'
[2025-11-11 20:09:19] info: z2m:mqtt: MQTT publish: topic 'zigbee2mqtt/Kitchen Water Sensor', payload '{"battery":71,"battery_low":false,"linkquality":87,"tamper":false,"water_leak":false}'
[2025-11-11 20:09:19] info: z2m:mqtt: MQTT publish: topic 'zigbee2mqtt/Kitchen Smoke Detector', payload '{"battery_state":"high","linkquality":61,"smoke":false,"tamper":false}'
[2025-11-11 20:09:19] info: z2m:mqtt: MQTT publish: topic 'zigbee2mqtt/Living Room Smoke Detector', payload '{"battery_state":"high","linkquality":236,"smoke":false,"tamper":false}'
[2025-11-11 20:09:19] info: z2m:mqtt: MQTT publish: topic 'zigbee2mqtt/Balcony Light', payload '{"backlight_mode":"normal","linkquality":61,"power_on_behavior":"previous","state":"OFF"}'
[2025-11-11 20:09:19] info: z2m:mqtt: MQTT publish: topic 'zigbee2mqtt/Balcony Window', payload '{"backlight_mode":"ON","calibration":"OFF","calibration_time":25,"indicator_mode":"off","linkquality":91,"motor_reversal":"OFF","moving":"STOP","position":100,"state":"OPEN"}'
[2025-11-11 20:09:19] info: z2m:mqtt: MQTT publish: topic 'zigbee2mqtt/LED Bar Switch', payload '{"backlight_mode":"normal","linkquality":51,"power_on_behavior":null,"power_on_behavior_left":"previous","state_center":"ON","state_left":"ON","state_right":"OFF"}'
[2025-11-11 20:09:19] info: z2m:mqtt: MQTT publish: topic 'zigbee2mqtt/Corridor Light', payload '{"backlight_mode":"normal","linkquality":51,"power_on_behavior":"previous","state":"OFF"}'
[2025-11-11 20:09:19] info: z2m:mqtt: MQTT publish: topic 'zigbee2mqtt/Bathroom Water Sensor', payload '{"battery":33,"battery_low":false,"linkquality":47,"tamper":false,"water_leak":false}'
[2025-11-11 20:09:19] info: z2m:mqtt: MQTT publish: topic 'zigbee2mqtt/Bathroom Light', payload '{"backlight_mode":"normal","linkquality":51,"power_on_behavior":"previous","state":"OFF"}'
[2025-11-11 20:09:19] info: z2m:mqtt: MQTT publish: topic 'zigbee2mqtt/Safe Room Light', payload '{"backlight_mode":"normal","linkquality":116,"power_on_behavior":"previous","state":"OFF"}'
[2025-11-11 20:09:19] info: z2m:mqtt: MQTT publish: topic 'zigbee2mqtt/Laundry Water Sensor', payload '{"battery":60,"battery_low":false,"linkquality":40,"tamper":false,"water_leak":false}'
[2025-11-11 20:09:19] info: z2m:mqtt: MQTT publish: topic 'zigbee2mqtt/Laundry Smoke Detector', payload '{"battery_state":"low","linkquality":40,"smoke":false,"tamper":false}'
[2025-11-11 20:09:19] info: z2m:mqtt: MQTT publish: topic 'zigbee2mqtt/Shower Light', payload '{"backlight_mode":"normal","linkquality":116,"power_on_behavior":"previous","state":"OFF"}'
[2025-11-11 20:09:19] info: z2m:mqtt: MQTT publish: topic 'zigbee2mqtt/Bedroom Smoke Detector', payload '{"battery_state":"high","linkquality":116,"smoke":false,"tamper":null}'
[2025-11-11 20:09:19] info: z2m:mqtt: MQTT publish: topic 'zigbee2mqtt/Bedroom Socket ', payload '{"child_lock":"UNLOCK","current":0.16,"energy":2353.8,"indicator_mode":"off/on","linkquality":87,"power":16,"power_outage_memory":"restore","state":"ON","update":{"installed_version":69,"latest_version":69,"state":"idle"},"voltage":220}'
[2025-11-11 20:09:19] info: z2m:mqtt: MQTT publish: topic 'zigbee2mqtt/UPS Network Socket', payload '{"child_lock":"UNLOCK","current":0.58,"energy":1851.07,"indicator_mode":"off/on","linkquality":112,"power":89,"power_outage_memory":"restore","state":"ON","update":{"installed_version":69,"latest_version":69,"state":"idle"},"voltage":219}'
[2025-11-11 20:09:19] info: z2m:mqtt: MQTT publish: topic 'zigbee2mqtt/Safe Room Smoke Detector', payload '{"battery_state":"high","linkquality":116,"smoke":false,"tamper":false}'
[2025-11-11 20:09:19] info: z2m:mqtt: MQTT publish: topic 'zigbee2mqtt/Shower Water Sensor', payload '{"battery":58,"battery_low":false,"linkquality":58,"tamper":false,"water_leak":false}'
[2025-11-11 20:09:19] info: z2m:mqtt: MQTT publish: topic 'zigbee2mqtt/Kitchen LED', payload '{"brightness":26,"do_not_disturb":null,"effect":null,"linkquality":58,"state":"ON"}'
[2025-11-11 20:09:19] info: z2m:mqtt: MQTT publish: topic 'zigbee2mqtt/Refrigerator Socket', payload '{"child_lock":"UNLOCK","current":0.89,"energy":3485.52,"indicator_mode":"off/on","linkquality":29,"power":195,"power_outage_memory":"on","state":"ON","update":{"installed_version":69,"latest_version":69,"state":"idle"},"voltage":220}'
[2025-11-11 20:09:19] info: z2m:mqtt: MQTT publish: topic 'zigbee2mqtt/Main Network Switch', payload '{"child_lock":"UNLOCK","countdown":0,"current":0.01,"energy":14.95,"indicator_mode":"off/on","linkquality":76,"power":0,"power_outage_memory":"on","state":"ON","update":{"installed_version":78,"latest_version":78,"state":"idle"},"voltage":225}'
[2025-11-11 20:09:19] info: z2m:mqtt: MQTT publish: topic 'zigbee2mqtt/Living Room Socket', payload '{"child_lock":"UNLOCK","current":0.48,"energy":1819.94,"indicator_mode":"off/on","linkquality":255,"power":52,"power_outage_memory":"restore","state":"ON","update":{"installed_version":69,"latest_version":69,"state":"idle"},"voltage":221}'
[2025-11-11 20:09:19] info: z2m:mqtt: MQTT publish: topic 'zigbee2mqtt/Boiler Switch', payload '{"backlight_mode":null,"linkquality":43,"power_on_behavior":"on","state":"ON"}'
[2025-11-11 20:09:19] info: z2m:mqtt: MQTT publish: topic 'zigbee2mqtt/Kitchen Switch', payload '{"backlight_mode":"normal","linkquality":94,"power_on_behavior":null,"power_on_behavior_left":"previous","state_left":"OFF","state_right":"OFF"}'
[2025-11-11 20:09:19] info: z2m:mqtt: MQTT publish: topic 'zigbee2mqtt/Living Room Temperature Sensor', payload '{"battery":100,"humidity":60.41,"linkquality":236,"temperature":25.73,"voltage":3000}'
[2025-11-11 20:09:19] info: z2m:mqtt: MQTT publish: topic 'zigbee2mqtt/Kitchen Temperature Sensor', payload '{"battery":100,"humidity":60.96,"linkquality":112,"temperature":25.54,"voltage":3000}'
[2025-11-11 20:09:19] info: z2m:mqtt: MQTT publish: topic 'zigbee2mqtt/Safe Room Temperature Sensor', payload '{"battery":100,"humidity":58.46,"linkquality":116,"temperature":26,"voltage":3000}'
[2025-11-11 20:09:19] info: z2m:mqtt: MQTT publish: topic 'zigbee2mqtt/Bedroom Temperature Sensor', payload '{"battery":100,"humidity":58.8,"linkquality":47,"temperature":24.53,"voltage":3000}'
[2025-11-11 20:09:19] info: z2m:mqtt: MQTT publish: topic 'zigbee2mqtt/Network Cabinet Temperature Sensor', payload '{"battery":100,"humidity":44.23,"linkquality":116,"temperature":31.62,"voltage":3000}'
[2025-11-11 20:09:19] info: z2m:mqtt: MQTT publish: topic 'zigbee2mqtt/Bathroom Temperature Sensor', payload '{"battery":100,"humidity":62.71,"linkquality":47,"temperature":25.07,"voltage":3000}'
[2025-11-11 20:09:19] info: z2m: Zigbee2MQTT started!
[2025-11-11 20:09:24] info: z2m:mqtt: MQTT publish: topic 'homeassistant/binary_sensor/1221051039810110150109113116116_0x00124b002e1dfa0e/connection_state/config', payload '{"default_entity_id":"binary_sensor.zigbee2mqtt_bridge_connection_state","device":{"hw_version":"ZStack3x0 20250325","identifiers":["zigbee2mqtt_bridge_0x00124b002e1dfa0e"],"manufacturer":"Zigbee2MQTT","model":"Bridge","name":"Zigbee2MQTT Bridge","sw_version":"2.6.3"},"device_class":"connectivity","entity_category":"diagnostic","name":"Connection state","object_id":"zigbee2mqtt_bridge_connection_state","origin":{"name":"Zigbee2MQTT","sw":"2.6.3","url":"https://www.zigbee2mqtt.io"},"payload_off":"offline","payload_on":"online","state_topic":"zigbee2mqtt/bridge/state","unique_id":"bridge_0x00124b002e1dfa0e_connection_state_zigbee2mqtt","value_template":"{{ value_json.state }}"}'
[2025-11-11 20:09:24] info: z2m:mqtt: MQTT publish: topic 'homeassistant/binary_sensor/1221051039810110150109113116116_0x00124b002e1dfa0e/restart_required/config', payload '{"availability":[{"topic":"zigbee2mqtt/bridge/state","value_template":"{{ value_json.state }}"}],"availability_mode":"all","default_entity_id":"binary_sensor.zigbee2mqtt_bridge_restart_required","device":{"hw_version":"ZStack3x0 20250325","identifiers":["zigbee2mqtt_bridge_0x00124b002e1dfa0e"],"manufacturer":"Zigbee2MQTT","model":"Bridge","name":"Zigbee2MQTT Bridge","sw_version":"2.6.3"},"device_class":"problem","enabled_by_default":false,"entity_category":"diagnostic","name":"Restart required","object_id":"zigbee2mqtt_bridge_restart_required","origin":{"name":"Zigbee2MQTT","sw":"2.6.3","url":"https://www.zigbee2mqtt.io"},"payload_off":false,"payload_on":true,"state_topic":"zigbee2mqtt/bridge/info","unique_id":"bridge_0x00124b002e1dfa0e_restart_required_zigbee2mqtt","value_template":"{{ value_json.restart_required }}"}'
[2025-11-11 20:09:24] info: z2m:mqtt: MQTT publish: topic 'homeassistant/button/1221051039810110150109113116116_0x00124b002e1dfa0e/restart/config', payload '{"availability":[{"topic":"zigbee2mqtt/bridge/state","value_template":"{{ value_json.state }}"}],"availability_mode":"all","command_topic":"zigbee2mqtt/bridge/request/restart","default_entity_id":"button.zigbee2mqtt_bridge_restart","device":{"hw_version":"ZStack3x0 20250325","identifiers":["zigbee2mqtt_bridge_0x00124b002e1dfa0e"],"manufacturer":"Zigbee2MQTT","model":"Bridge","name":"Zigbee2MQTT Bridge","sw_version":"2.6.3"},"device_class":"restart","name":"Restart","object_id":"zigbee2mqtt_bridge_restart","origin":{"name":"Zigbee2MQTT","sw":"2.6.3","url":"https://www.zigbee2mqtt.io"},"payload_press":"","unique_id":"bridge_0x00124b002e1dfa0e_restart_zigbee2mqtt"}'
[2025-11-11 20:09:24] info: z2m:mqtt: MQTT publish: topic 'homeassistant/select/1221051039810110150109113116116_0x00124b002e1dfa0e/log_level/config', payload '{"availability":[{"topic":"zigbee2mqtt/bridge/state","value_template":"{{ value_json.state }}"}],"availability_mode":"all","command_template":"{\"options\": {\"advanced\": {\"log_level\": \"{{ value }}\" } } }","command_topic":"zigbee2mqtt/bridge/request/options","default_entity_id":"select.zigbee2mqtt_bridge_log_level","device":{"hw_version":"ZStack3x0 20250325","identifiers":["zigbee2mqtt_bridge_0x00124b002e1dfa0e"],"manufacturer":"Zigbee2MQTT","model":"Bridge","name":"Zigbee2MQTT Bridge","sw_version":"2.6.3"},"entity_category":"config","name":"Log level","object_id":"zigbee2mqtt_bridge_log_level","options":["error","warning","info","debug"],"origin":{"name":"Zigbee2MQTT","sw":"2.6.3","url":"https://www.zigbee2mqtt.io"},"state_topic":"zigbee2mqtt/bridge/info","unique_id":"bridge_0x00124b002e1dfa0e_log_level_zigbee2mqtt","value_template":"{{ value_json.log_level | lower }}"}'
[2025-11-11 20:09:24] info: z2m:mqtt: MQTT publish: topic 'homeassistant/sensor/1221051039810110150109113116116_0x00124b002e1dfa0e/version/config', payload '{"availability":[{"topic":"zigbee2mqtt/bridge/state","value_template":"{{ value_json.state }}"}],"availability_mode":"all","default_entity_id":"sensor.zigbee2mqtt_bridge_version","device":{"hw_version":"ZStack3x0 20250325","identifiers":["zigbee2mqtt_bridge_0x00124b002e1dfa0e"],"manufacturer":"Zigbee2MQTT","model":"Bridge","name":"Zigbee2MQTT Bridge","sw_version":"2.6.3"},"entity_category":"diagnostic","icon":"mdi:zigbee","name":"Version","object_id":"zigbee2mqtt_bridge_version","origin":{"name":"Zigbee2MQTT","sw":"2.6.3","url":"https://www.zigbee2mqtt.io"},"state_topic":"zigbee2mqtt/bridge/info","unique_id":"bridge_0x00124b002e1dfa0e_version_zigbee2mqtt","value_template":"{{ value_json.version }}"}'
[2025-11-11 20:09:24] info: z2m:mqtt: MQTT publish: topic 'homeassistant/sensor/1221051039810110150109113116116_0x00124b002e1dfa0e/coordinator_version/config', payload '{"availability":[{"topic":"zigbee2mqtt/bridge/state","value_template":"{{ value_json.state }}"}],"availability_mode":"all","default_entity_id":"sensor.zigbee2mqtt_bridge_coordinator_version","device":{"hw_version":"ZStack3x0 20250325","identifiers":["zigbee2mqtt_bridge_0x00124b002e1dfa0e"],"manufacturer":"Zigbee2MQTT","model":"Bridge","name":"Zigbee2MQTT Bridge","sw_version":"2.6.3"},"enabled_by_default":false,"entity_category":"diagnostic","icon":"mdi:chip","name":"Coordinator version","object_id":"zigbee2mqtt_bridge_coordinator_version","origin":{"name":"Zigbee2MQTT","sw":"2.6.3","url":"https://www.zigbee2mqtt.io"},"state_topic":"zigbee2mqtt/bridge/info","unique_id":"bridge_0x00124b002e1dfa0e_coordinator_version_zigbee2mqtt","value_template":"{{ value_json.coordinator.meta.revision }}"}'
[2025-11-11 20:09:24] info: z2m:mqtt: MQTT publish: topic 'homeassistant/sensor/1221051039810110150109113116116_0x00124b002e1dfa0e/network_map/config', payload '{"availability":[{"topic":"zigbee2mqtt/bridge/state","value_template":"{{ value_json.state }}"}],"availability_mode":"all","default_entity_id":"sensor.zigbee2mqtt_bridge_network_map","device":{"hw_version":"ZStack3x0 20250325","identifiers":["zigbee2mqtt_bridge_0x00124b002e1dfa0e"],"manufacturer":"Zigbee2MQTT","model":"Bridge","name":"Zigbee2MQTT Bridge","sw_version":"2.6.3"},"enabled_by_default":false,"entity_category":"diagnostic","json_attributes_template":"{{ value_json.data.value | tojson }}","json_attributes_topic":"zigbee2mqtt/bridge/response/networkmap","name":"Network map","object_id":"zigbee2mqtt_bridge_network_map","origin":{"name":"Zigbee2MQTT","sw":"2.6.3","url":"https://www.zigbee2mqtt.io"},"state_topic":"zigbee2mqtt/bridge/response/networkmap","unique_id":"bridge_0x00124b002e1dfa0e_network_map_zigbee2mqtt","value_template":"{{ now().strftime('%Y-%m-%d %H:%M:%S') }}"}'
[2025-11-11 20:09:24] info: z2m:mqtt: MQTT publish: topic 'homeassistant/switch/1221051039810110150109113116116_0x00124b002e1dfa0e/permit_join/config', payload '{"availability":[{"topic":"zigbee2mqtt/bridge/state","value_template":"{{ value_json.state }}"}],"availability_mode":"all","command_topic":"zigbee2mqtt/bridge/request/permit_join","default_entity_id":"switch.zigbee2mqtt_bridge_permit_join","device":{"hw_version":"ZStack3x0 20250325","identifiers":["zigbee2mqtt_bridge_0x00124b002e1dfa0e"],"manufacturer":"Zigbee2MQTT","model":"Bridge","name":"Zigbee2MQTT Bridge","sw_version":"2.6.3"},"icon":"mdi:human-greeting-proximity","name":"Permit join","object_id":"zigbee2mqtt_bridge_permit_join","origin":{"name":"Zigbee2MQTT","sw":"2.6.3","url":"https://www.zigbee2mqtt.io"},"payload_off":"{\"time\": 0}","payload_on":"{\"time\": 254}","state_off":"false","state_on":"true","state_topic":"zigbee2mqtt/bridge/info","unique_id":"bridge_0x00124b002e1dfa0e_permit_join_zigbee2mqtt","value_template":"{{ value_json.permit_join | lower }}"}'
[2025-11-11 20:09:47] error: z2m: Publish 'set' 'state' to 'Kitchen Switch' failed: 'Error: ZCL command 0xa4c138f1d8539d05/1 genOnOff.on({}, {"timeout":10000,"disableResponse":false,"disableRecovery":false,"disableDefaultResponse":false,"direction":0,"reservedBits":0,"writeUndiv":false}) failed (Timeout - 13398 - 1 - 0 - 6 - 11 after 10000ms)'
[2025-11-11 20:10:14] error: z2m: Publish 'set' 'state' to 'Living Room Light' failed: 'Error: ZCL command 0xa4c138a2ad81bd63/1 genOnOff.on({}, {"timeout":10000,"disableResponse":false,"disableRecovery":false,"disableDefaultResponse":false,"direction":0,"reservedBits":0,"writeUndiv":false}) failed (Data request failed with error: 'No network route' (205))'
