SMA Integration from HACS, Inverter have to be re-loaded manually
I have 2 SMA inverters, connected via SMA Device Plus in the Home Assistant. This worked well for a while. The current situation is that I have to reload the inverters every day manually
in the integration so that the values are recognized.
I have tested the following
  1. Delete inverters in the integration, no success
  2. Delete integration, reinstall everything. Success, runs for a few weeks, then the error described above occurs again.
What could this be?
Thanks for your help
Greetings
Haase
